Even the library does NOT work: I decided to take a look at Cube's emitted code. The compiled library boilerplate (ST's USB library + Cube, its hard dependency) took 16,144 out of 16,384 available bytes of Flash memory with -Og optimization, 13,764 if optimized with -Os (breaking debugging.) So 240 bytes for the whole application?!? I am seriously wondering how did ST fit their DFU bootloader into the 13k mask ROM on the chip...
Currently my hand written code used 2,020 bytes. (No USB yet, not going to touch the bloatware known as Cube or ST's libraries any time soon.)
Wow, that's gotta be a new awesome checkbox functionality. Yes it has USB. Yes the code uses 99% of the flash. So what? We said it has USB
It also has a bunch of other peripherals. All of them on the same pins. Checkbox checked!
Umm what are you talking about?
I have enabled the following peripherals in Cube, all of which needed for my application:
* USB (duh)
* External crystal (dependency of USB)
* 2 PWM on TIM3 (to dim the light and the status LED)
* The USB HID Class driver
* Serial port (for debug messages)
When I tried removing the serial port driver (as if in the final product, where debug messages are no longer needed) and -Os optimization there is still 11,992 bytes of boilerplate.
Just for fun, enabling just the same set of peripherals as my own startup code, Cube emitted 3,596 bytes of code under -Os. While my own code emitted 2,020 bytes with -Og (a lot less optimization than -Os.) Speaking of bloat, that is 1.5k pure bloat introduced by the underwhelming architecture and WET code.
