Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
anyone using Parallela ? 16-core Epiphany RISC SOC + Zynq SOC (FPGA + ARM A9)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: anyone using Parallela ? 16-core Epiphany RISC SOC + Zynq SOC (FPGA + ARM A9) (Read 2953 times)
legacy
Super Contributor
Country:
on:
December 06, 2016, 04:40:39 pm »
is anyone using the
Parallella
board ? ( 99 USD )
if so, for which project
Logged
helius
Super Contributor
Country:
Re: anyone using Parallela ? 16-core Epiphany RISC SOC + Zynq SOC (FPGA + ARM A9)
Reply #1 on:
December 06, 2016, 05:08:19 pm »
Be aware that there is a design error on the board; the designers failed to correctly consider inrush currents (as taught in Linear Technology's AN88) and as a result they are easily damaged.
Logged
legacy
Super Contributor
Country:
Reply #2 on:
December 06, 2016, 07:57:23 pm »
Quote from: helius on December 06, 2016, 05:08:19 pm
has been fixed in the last releases ?
Logged
thm_w
Super Contributor
Country:
Non-expert
Reply #3 on:
December 06, 2016, 08:32:04 pm »
The psu chip used has a max Vin of 6.5V:
http://www.intersil.com/content/dam/Intersil/documents/isl9/isl9305h.pdf
http://www.intersil.com/content/dam/Intersil/documents/isl9/isl9307.pdf
AN88 posted lists an example of over 2x voltage being applied. So this chip could presumably get over 10V.
Schematic is listed as Rev 1 still. So it seems like it was not fixed?
Would be possible to add a TVS across C237:
http://www.parallella.org/docs/parallella_schematic.pdf
Logged
Profile -> Modify profile -> Look and Layout -> Don't show users' signatures
bktemp
Super Contributor
Country:
Reply #4 on:
December 06, 2016, 08:42:09 pm »
Adding a TVS could work, but the transition of most TVS diodes is too soft for such a small voltage difference (5V->6.5V). The inrush current can easily >10A and the TVS must be able to limit the voltage at this current.
But there is a much easier solution: Just add an electrolytic capacitor of about 10x the value of the ceramic capacitor. Its ESR will dampen any overshoots.
Logged
ebclr
Super Contributor
Country:
Reply #5 on:
December 09, 2016, 06:32:33 am »
I bought basically to play with the Zynq SOC, it's the cheapest , and util now no problem, it's used only to research on FPGA
Logged
legacy
Super Contributor
Country:
Reply #6 on:
December 09, 2016, 03:52:35 pm »
ummm, I'd like to port my SoftCore on the FPGA, too
but I'd also like to play with the Epiphany SoC
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
