m68k-unknown-linux-gnu-gcc -mcpu=5282 -c hAllo.c -o hAllo.o
cc1: error: unrecognized command line option "-mcpu=5282"
target=m68k-unknown-linux-gnu
target=m68k-elf
m68k-unknown-linux-gnu-gcc -v
Using built-in specs.
Target: m68k-unknown-linux-gnu
Configured with: /var/tmp/portage/cross-m68k-unknown-linux-gnu/gcc-4.1.2/work/gcc-4.1.2/configure
--host=i686-pc-linux-gnu
--target=m68k-unknown-linux-gnu
--build=i686-pc-linux-gnu
--prefix=/usr
--bindir=/usr/i686-pc-linux-gnu/m68k-unknown-linux-gnu/gcc-bin/4.1.2
--includedir=/usr/lib/gcc/m68k-unknown-linux-gnu/4.1.2/include
--datadir=/usr/share/gcc-data/m68k-unknown-linux-gnu/4.1.2
--mandir=/usr/share/gcc-data/m68k-unknown-linux-gnu/4.1.2/man
--infodir=/usr/share/gcc-data/m68k-unknown-linux-gnu/4.1.2/info
--with-gxx-include-dir=/usr/lib/gcc/m68k-unknown-linux-gnu/4.1.2/include/g++-v4
--enable-languages=c
--enable-obsolete
--enable-secureplt
--disable-werror
--with-system-zlib
--enable-nls
--without-included-gettext
--enable-checking=release
--enable-poison-system-directories
--disable-shared
--disable-threads
--without-headers
--enable-__cxa_atexit
--enable-clocale=gnu
--disable-multilib
--disable-altivec
--disable-libgcj
--disable-libmudflap
--disable-libssp
Thread model: single
gcc version 4.1.2 (Gentoo 4.1.2 p1.6)
m68k-unknown-linux-gnu-gcc -m528x -c hAllo.c -o hAllo.o
You using GCC anyway?
What does the target dump/help looks like ?
opts="
-mcpu32
-m68000
-m68010
-m68020
-mc68020
-m68030
-m68040
-m68060
-m5200
-m5206e
-m528x
-m5307
-m5407
-m68020-40
-m68020-60
for opt in $opts
do
echo "$opt"
m68k-unknown-linux-gnu-gcc $opt -c hAllo.c -o obj/hAllo$opt.o
done
-mcpu32
-m68000
-m68010
cc1: error: unrecognized command line option "-m68010"
-m68020
-mc68020
-m68030
-m68040
-m68060
-m5200
-m5206e
-m528x
-m5307
-m5407
-m68020-40
-m68020-60
crossdev --b 2.25.1-r1 --g 4.1.2 --l 2.22-r1 --k 4.3 -s2 -t m68k-unknown-linux-gnu --without-headers -v
crossdev --b 2.25.1-r1 --g 4.3.1 --l 2.22-r1 --k 4.3 -s2 -t m68k-elf --without-headers -v
gcc-config -l
[1] i686-pc-linux-gnu-4.1.2
[2] i686-pc-linux-gnu-4.9.3 *
[3] m68k-unknown-linux-gnu-4.1.2 *
[4] mips64-unknown-linux-gnu-4.1.2
[5] mips64-unknown-linux-gnu-5.3.0 *
[6] powerpc-unknown-linux-gnu-4.1.2 *
[3] m68k-elf-4.2.4 *
[4] m68k-unknown-linux-gnu-4.1.2 *
[5] mips64-unknown-linux-gnu-4.1.2
[6] mips64-unknown-linux-gnu-5.3.0 *
[7] powerpc-unknown-linux-gnu-4.1.2 *
so, no one on ColdFire® M5282EVB or similar boards.
And get some ARM development boards while you are at it
