I'm a beginner in Arduino and I am trying to make a safe using a keypad, lcd and servo. I'm using 2 codes combined from 2 different videos. Everything was working fine until I typed code for the servo motor( under if line). Now when I want to compile it's giving me error "setLocked was not declared in this scope". Help please.
This is my code:
#include <Keypad.h>
#include <LiquidCrystal.h> //include LCD library (standard library)
#include <Keypad.h> //include keypad library
#define redLED 10 //define the LED pins
#define greenLED 11
char* password = "1234"; //create a password
int pozisyon = 0; //keypad position
const byte rows = 4; //number of the keypad's rows and columns
const byte cols = 4;
char keyMap [rows] [cols] = { //define the symbols on the buttons of the keypad
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins [rows] = {1, 2, 3, 4}; //pins of the keypad
byte colPins [cols] = {5, 6, 7, 8};
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
LiquidCrystal lcd (A0, A1, A2, A3, A4, A5); // pins of the LCD. (RS, E, D4, D5, D6, D7)
void setup() {
lcd.begin(16, 2);
pinMode(redLED, OUTPUT); //set the LED as an output
pinMode(greenLED, OUTPUT);
setLocked (true); //state of the password
void loop() {
char whichKey = myKeypad.getKey(); //define which key is pressed with getKey
lcd.setCursor(0, 0);
lcd.print(" Welcome");
lcd.setCursor(0, 1);
lcd.print(" Enter Password");
if (whichKey == '*' || whichKey == '#' || whichKey == 'A' || //define invalid keys
whichKey == 'B' || whichKey == 'C' || whichKey == 'D') {
pozisyon = 0;
setLocked (true);
lcd.clear();
lcd.print(" Invalid Key!");
delay(1000);
lcd.clear();
if (whichKey == password [pozisyon]) {
pozisyon ++;
if (pozisyon == 4) {
setLocked (false);
lcd.clear();
lcd.print("*** Verified ***");
delay(2000);
for (pos = 0; pos <= 180; pos += 1) {
myservo.write(pos);
delay(15);
lcd.clear();
lcd.print("Unlocked");
lcd.print("--------");
delay(7000);
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
lcd.clear();
delay(100);
void setLocked(int locked) {
if (locked) {
digitalWrite(redLED, HIGH);
digitalWrite(greenLED, LOW);
else {
digitalWrite(redLED, LOW);
digitalWrite(greenLED, HIGH);
