Author Topic: Arduino code suddenly stopped working after clicking the reset button [SOLVED]  (Read 5913 times)
Offline ZeTeXTopic starter
  • Country: il
  • When in doubt, add more flux.
I have the following library installed and the following code flashed onto the arduino:
https://github.com/buxtronix/arduino/tree/master/libraries/Rotary
 * Example using the Rotary library, dumping integers to the serial
 * port. The integers increment or decrement depending on the direction
 * of rotation.
 * This example uses interrupts rather than polling.
#include <Rotary.h>
// Rotary encoder is wired with the common to ground and the two
// outputs to pins 2 and 3.
Rotary rotary = Rotary(2, 3);
// Counter that will be incremented or decremented by rotation.
int counter = 0;
void setup() {
  Serial.begin(57600);
  attachInterrupt(0, rotate, CHANGE);
  attachInterrupt(1, rotate, CHANGE);
void loop() {
// rotate is called anytime the rotary inputs change state.
void rotate() {
  unsigned char result = rotary.process();
  if (result == DIR_CW) {
    counter++;
    Serial.println(counter);
  } else if (result == DIR_CCW) {
    counter--;
This code worked great for reading the encoder, but I tried clicking on the reset button on the arduino and the code just stopped working even after I recompiled and flashed it, so I've tried other rotary encoder library that I found on google and it worked great so it is something about the code that has f*cked.
I've also tried re-downloading the library and installing it, I tried random examples from the arduino software and they all worked, I tried connecting the encoder directly to the arduino pins without the breadboard, I'm out of ideas.
What could be the problem?
« Last Edit: January 07, 2017, 04:42:09 pm by ZeTeX »
Offline rstofer
Re: Arduino code suddenly stopped working after clicking the reset button
« Reply #1 on: December 30, 2016, 04:29:16 pm »
It seems to me that rotate() is some kind of interrupt handler.  If so, I wouldn't be putting Serial.Print statements inside the handler.  Get in, do as little as possible and get out.  Leave the printing for loop().  Your interrupt routine should just update the count.
  • Country: il
« Reply #2 on: December 30, 2016, 10:35:04 pm »
OK, I moved Serial.print to void loop, and removed it from void rotary.
Code looks like this now :
 * of rotation.
#include <Rotary.h>
int counter = 0;
void setup() {
void rotate() {
    counter++;
    counter--;
void loop() {
But still, same result, the counter doesn't update at all. the serial monitor just spams 0 over and over again like it should.
problem here is that the code worked before, but suddenly it doesn't, how can you debug something like that?
The following users thanked this post: MarkF
Offline retrolefty
« Reply #3 on: December 30, 2016, 10:52:18 pm »
Unless you have wired external pull-up resistors for the two encoder signals you should use pinMode function to enable internal pull-ups for pins 2 and 3 in your setup fuction.
  • Country: il
« Reply #4 on: December 30, 2016, 11:14:02 pm »
I have tried with external 10k pull ups. nothing changes.
Offline MickM
« Reply #5 on: December 31, 2016, 12:49:27 am »
Where do the interrupts get enabled?
Move the call to rotary.process() into loop().
Offline linux-works
    • netstuff
« Reply #6 on: December 31, 2016, 12:58:52 am »
like others have said, so nearly no work inside the ISR.
in fact, I suggest you abandon the isr and just poll.  there are examples for this including the use of a lookup table for faster if/then logic.
I'm using a high res (400ppr) opto rotary and just polling for it and I nearly never drop events and definitely never count backwards by mistake (which often happens if you lose an event and dont' have a full state table implemented).
Offline MarkF
« Reply #7 on: December 31, 2016, 04:23:19 am »
This is a wonderful example of why I avoid using unknown libraries from the web and write my own at all costs. (35 years of experience doing code development here.)
Having a print statement to the console will kill any kind of execution rate you're trying to achieve.
See attached file for reading an encoder without a lookup table or a bunch of "if" statements. I use an ISR to provide my polling rate and NOT to detect knob movement. One more thing is to USE the recommended filter and pullup configuration in the data sheet.
Linux-works, what polling rate do you use?
« Last Edit: December 31, 2016, 04:29:54 am by MarkF »
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #8 on: December 31, 2016, 07:16:59 am »
From the couch:
 * of rotation.
#include <Rotary.h>
//int counter = 0;
// var shared between interrupt handler and common code must be volatile!
volatile int counter = 0;      // <=========
void setup() {
  // turn on interrupts
  interupts();   // <============
void rotate() {
    counter++;
  } else {   // if (result == DIR_CCW) {    <== maybe the return value is something else?
    counter--;
void loop() {
 :popcorn:
« Last Edit: December 31, 2016, 07:18:39 am by obiwanjacobi »
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
  • Country: il
« Reply #9 on: December 31, 2016, 10:49:42 am »
From the couch:
 * of rotation.
#include <Rotary.h>
//int counter = 0;
void setup() {
void rotate() {
    counter++;
    counter--;
void loop() {
 :popcorn:
This code kinda works, but it doesn't jump by 1 in the counter but more like 2+. also you can only move the encoder in 1 direction.
there is also a polling example:
 * of rotation.
 * This example uses polling rather than interrupts.
#include <Rotary.h>
// outputs to pins 5 and 6.
Rotary rotary = Rotary(5, 6);
void setup() {
void loop() {
    counter++;
    counter--;
that's also doesn't work.
I took the original code from here:
http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html
    • Marctronix Blog
« Reply #10 on: December 31, 2016, 11:24:10 am »
That means the switches in the decoder are bouncing. That library should have some way to set the bounce-timeout... (I hope).
Try printing the 'result' var, perhaps with a switch to translate to text...
Offline chris_leyson
  • Country: wales
« Reply #11 on: December 31, 2016, 01:17:42 pm »
Some time ago I was looking for a reliable and simple method for decoding quadrature signals from a rotary encoder and I found this really nice solution thanks to Oleg Mazurov, https://www.circuitsathome.com/mcu/reading-rotary-encoder-on-arduino/. It's an  elegant solution using a state table and doesn't need debouncing harware but I added 10n caps across the encoder switches just to clean up the edges a little bit, pullups were 4k7.
I used two encoders, TE Connectivity DPL12 24 pulse per revolution, encoder 1 wired to RB0,RB1 and encoder 2 wired to RB2,RB3 and PIC interrupt on change to call an ISR. I should point out that the technique works best if the encoders are wired to consecutive port pins. Relavent code snippets posted below.
int    encval_1 = 0;
int    encval_2 = 0;
int    count_1 = 0;
int    count_2 = 0;
unsigned int    old_state_1 = 0xffff;
unsigned int    old_state_2 = 0xffff;
// Change notice interrupt:- Incremental encoders
void __attribute__((__interrupt__, no_auto_psv)) _CNInterrupt(void)
   static int enc_state[] = {0,1,-1,0,-1,0,0,1,1,0,0,-1,0,-1,1,0};
   old_state_1 = old_state_1 << 2;
   old_state_1 |= (PORTB & 0x0003);
   encval_1 = encval_1 + (enc_state[old_state_1 & 0x0f]);
   if(encval_1 > 3){ count_1++; encval_1 = 0;}
   else if(encval_1 < -3){ count_1--; encval_1 = 0;}
   // because old_state_2 bit pairs are swapped over
   // encstate has opposite sign
   old_state_2 = old_state_2 >> 2;
   old_state_2 |= (PORTB & 0x000c);
   encval_2 = encval_2 - (enc_state[old_state_2 & 0x0f]);
   if(encval_2 > 3){ count_2++; encval_2 = 0;}
   else if(encval_2 < -3){ count_2--; encval_2 = 0;}
   IFS1bits.CNIF = 0;
Because encoder 2 needs a right shift instead of a left shift then the two bit pairs that make up the 4-bit table address, old state<<2 and old state which is actually the new state are swapped over and this can be fixed by changing the sign of enc_state. It might look a bit cryptic but once you work through Oleg's description it's not to difficult to see how it works. The encoders increment or decrement a pair of signed 2-bit counters encval1 and encval2 and when they overflow or underflow the counters count_1 and count_2 are incremented or decremented. Because of a little bit of remaining switch bounce the variable encval might jitter by +/- one count but the technique automatically recovers and no matter how fast you spin the encoders they never missed a count.
Chris
« Last Edit: December 31, 2016, 01:32:03 pm by chris_leyson »
Offline linux-works
    • netstuff
« Reply #12 on: December 31, 2016, 04:07:06 pm »
that last post is using the code  that I also found online a few years ago.  its the fastest I could find and the lookup table and statefulness of it is brilliant.
just use that and poll.
as for polling rate, every spare cycle, I poll, in my main loop.  don't know the rate, though.
  • Country: il
« Reply #13 on: December 31, 2016, 05:04:20 pm »
int    encval_1 = 0;
int    encval_2 = 0;
int    count_1 = 0;
int    count_2 = 0;
   IFS1bits.CNIF = 0;
Chris
I've used this code from the site:
/* Rotary encoder read example */
#define ENC_A 14
#define ENC_B 15
#define ENC_PORT PINC
void setup()
  /* Setup encoder pins as inputs */
  pinMode(ENC_A, INPUT);
  digitalWrite(ENC_A, HIGH);
  pinMode(ENC_B, INPUT);
  digitalWrite(ENC_B, HIGH);
  Serial.begin (115200);
  Serial.println("Start");
void loop()
 static uint8_t counter = 0;      //this variable will be changed by encoder input
 int8_t tmpdata;
  tmpdata = read_encoder();
  if( tmpdata ) {
    Serial.print("Counter value: ");
    Serial.println(counter, DEC);
    counter += tmpdata;
/* returns change in encoder state (-1,0,1) */
int8_t read_encoder()
  static int8_t enc_states[] = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0};
  static uint8_t old_AB = 0;
  old_AB <<= 2;                   //remember previous state
  old_AB |= ( ENC_PORT & 0x03 );  //add current state
  return ( enc_states[( old_AB & 0x0f )]);
But it doesn't work that well for me, I've defined the encoder like that:
#define ENC_A 8
#define ENC_B 9
#define ENC_PORT PINB
and connected it to pin 8 and 9.
but at the serial monitor I get:
Counter value: 0
Counter value: 1
for about each step, so if I move the encoder 3 steps it will be like this:
Counter value: 0
Counter value: 1
Counter value: 0
Counter value: 1
Counter value: 0
Counter value: 1
What is really annoying is that the code I posted at the start of the topic did work but suddenly it stopped, how can you explain that?
« Last Edit: December 31, 2016, 05:06:18 pm by ZeTeX »
Offline rstofer
« Reply #14 on: December 31, 2016, 05:28:43 pm »
Well, the answer is obvious but not likely satisfying:  Your code changed between the first and second evolutions.  Somewhere, somehow, you changed something.  Just a lilttle 'clean up', 'I don't need this...' or something like that.  It happens all the time.  A little brain fade and things don't work anymore.
I don't have a way to replicate your problem so I don't know if your posted code works or not.  Libraries, written by others, are always suspect!
Offline MarkF
« Reply #15 on: January 01, 2017, 06:03:06 am »
Here is a code snippet I use to read an encoder with a push switch:
// PORTCbits.RC0 = encoder switch
// PORTCbits.RC1 = encoder phase 0
// PORTCbits.RC2 = encoder phase 1
uint8_t currP0;      // encoder phase 0 (current value)
uint8_t lastP0;      // encoder phase 0 (last value)
uint8_t lastSw0;     // encoder switch (last value)
int8_t en0;          // encoder value (0=no change, (-)=CCW count, (+)=CW count)
uint8_t sw0;         // encodeeer switch;
// Main entry
void main(void)
   uint8_t count;
   // Initialize encoder variables
   en0=0;
   sw0=0;
   lastP0=PORTCbits.RC1;
   lastSw0=PORTCbits.RC0;
   // Setup interrupt here
   // (Recommend 50Hz or greater polling rate)
   // Enter main loop
   while (1) {
      // Encoder knob processing
      if (en0 != 0) {
         count=en0;  // save count
         en0=0;      // reset encoder value quickly
                     // so we don't miss any changes
         // DO SOMETHING WITH ENCODER COUNT
      // Encoder switch processing
      if (sw0 != 0) {
         sw0=0;      // reset enocder switch state quickly
                     // so we don't miss any presses
         // DO SOMETHING WITH ENCODER SWITCH PRESS
      // DO OTHER PERIODIC PROCESSING
// Interrupt service entry
void isr(void)
   uint8_t pin;
   // Read encoder knob
   currP0=PORTCbits.RC1;         // encoder phase 0
   if (lastP0 == 0 && currP0 == 1) {
      if (PORTCbits.RC2 == 1)    // encoder phase 1
         en0--;   // increment CCW count for main loop
      else
         en0++;   // increment CW count for main loop
   lastP0=currP0;                // save current phase 0
   // Read encoder switch
   pin=PORTCbits.RC0;            // get current switch state
   if (lastSw0 == 0 && pin == 1)
      sw0=1;      // set switch state for main loop
   lastSw0=pin;                  // save switch state
« Last Edit: January 01, 2017, 06:04:40 am by MarkF »
  • Country: il
« Reply #16 on: January 06, 2017, 11:40:17 pm »
#define ENC_A 14
#define ENC_B 15
void setup()
void loop()
 int8_t tmpdata;
  if( tmpdata ) {
    counter += tmpdata;
#define ENC_A 8
#define ENC_B 9
Counter value: 0
Counter value: 1
Counter value: 0
Counter value: 1
Counter value: 0
Counter value: 1
Counter value: 0
Counter value: 1
Does anybody knows how to change:
Counter value: 0
Counter value: 1
every step, to a counter that just adds 1 in cc or cw rotation or remove 1 in cow or cc rotation?
I'm desperate, no code other then the really simple one basically work for me, its like something happened to the arduino!
« Last Edit: January 06, 2017, 11:44:49 pm by ZeTeX »
Offline rstofer
« Reply #17 on: January 07, 2017, 12:23:08 am »
Debugging is something of an art...
When you read the pins, immediately send them to a pair of LEDs.  That way you will know what was read.
I didn't work through your state tables but it might be worth your time to walk through a typical set of transitions.
« Last Edit: January 07, 2017, 03:43:28 am by rstofer »
  • Country: il
« Reply #18 on: January 07, 2017, 04:41:36 pm »
I FOUND THE PROBLEM! FINALLY!
and it is not the code, the problem was that I made a small encoder module because last time I just soldered pin headers to the encoder the encoder pins just broke, and somehow there was not a good soldering connection (which is weird because by eye it looks perfect) so I have just re-soldered it and and it works great, ISR or just polling. "never assume anything in electronics" - I assumed the problem was the code and not the encoder, silly me.
Thanks @rstofer, I connected a resistor and a led to see if the led would light up the way it should (00, 01, 11, 11) and I noticed only 1 led was on, the other one just didn't light up, measured continuity and found the problem. 2minutes fix, 6 hours+ troubleshooting a code that works.
« Last Edit: January 07, 2017, 04:44:09 pm by ZeTeX »
