Author Topic: ARM assembler syntax query  (Read 1805 times)
Offline AussieBruceTopic starter
« on: March 30, 2022, 09:17:26 am »
Hi,  I'm wading through a heap of system assembler files to sort out an IRQ problem on an ARM-7 target. Included is the following, they look like memory allocations.  I can't find any reference to the 'b', is it shorthand for 'byte'? In fact, from the module context these should be  exception/interrupt vectors,  more than 8 bits. What do these lines do?
undef_handler:
  b undef_handler
swi_handler:
  b swi_handler
pabort_handler:
  b pabort_handler
Offline retiredfeline
Re: ARM assembler syntax query
« Reply #1 on: March 30, 2022, 09:20:40 am »
Maybe branch unconditionally, i.e. handlers are infinite loops?
Offline westfw
« Reply #2 on: March 30, 2022, 09:21:03 am »
“B” is “branch” (unconditional)
You are looking at tiny little default interrupt handlers that are short infinite loops.
Offline abyrvalg
« Reply #3 on: March 30, 2022, 09:35:12 am »
To clarify a bit: on ARM7 the vector table doesn’t hold addresses (unlike Cortex-M etc), the CPU jumps right into the table and each entry is a single instruction (so it is typical to use either “B real_handler” or “LDR PC, =real_handler”).
Offline SiliconWizard
« Reply #4 on: March 30, 2022, 05:36:48 pm »
Yes. This is not maybe, this is for sure.
Online rstofer
« Reply #5 on: March 30, 2022, 05:46:01 pm »
Sometimes you will see something like:
b 1b
This is a branch to the label 1 backward
b 1f is a branch to label 1 forward
https://stackoverflow.com/questions/27353096/1b-and-1f-in-gnu-assembly
