Yes, I am taking the class and finding it horrendously low entry level. Do not take me wrong. The class has 26,000 students enrolled, so it is a success and for sure helps a lot of people.
I am a retired engineer, EE by education, but except for the early eight years in heavy process control, the rest, mostly software. I have not touched electronics since the 70s. The last thing I did back then was design and wire wrap together an 8080 with one KB of static memory and with a switches and LEDs debug console. Those were the times of the Altair.
Then I bought and assembled the Intel 8085 Kit (SDK85 ?). Now, retired, getting back into electronics as a hobby (Bac2Volts
I decided to attend the class because I wanted to take a look at a current development tooling for MCUs. I have enjoyed getting into the TI TM4C123 LaunchPad and touching ARM and Keil. Before this superficial contact with ARM, I was thinking about getting into MCUs with 8 bits, may be Arduino. Now I am starting to think that it would make sense to just deal with ARM at different levels, depending on the project. That said, I am trying to grasp what the differences between manufacturers and ARM levels are. I saw the three books as reference material for the class, and thinking that they would probably be used as material for the regular EE curriculum, I wondered if they would be higher level. Unfortunately I hear you, they are not, so I will look for the common ARM documentation.
Thank you for the comments
Tony - Back2Volts
