Hello Everyone!
Does anyone ever tried to rescue ATmega328 with high voltage programming?
I'm using AVR Dragon to rescue 20 microcontroller with locked fuses!
I made an adapter board, to connect the device I followed
Devicesheet SCKT3200D2, but I'm not sure of connections because it specifies connections only for 28 pin devices.
So I made my own cross table (attached).
Nothing to do... with my adapter I'm able to program (fresh devices) in ICSP mode and read Programmed devices, but it won't work in HV Programming mode...
I get the following error:
Unable to enter programming mode. The read device ID does not match the selected device or any other supported devices.
Please verify device selection, interface settings, target power and connections to the target device.
Severity: ERROR
ComponentId: 20100
StatusCode: 131101
ModuleName: TCF (TCF command: Device:startSession failed.)
Unexpected signature 0x00efefef (expected 0x001e9514).
Any idea? Are my connections wrong?
Thank you!
