Author Topic: ATmega4809 won't respond  (Read 1830 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: July 10, 2019, 10:19:06 am »
I wrote a program for a project with an atmega3208 an got absolutely nothing out. So I started to play with the dev board with a 4809 on it. I wrote the below simplest of programs but other than clock out I get nothing other that some pins permanently low or high:
int main(void)
CCP = 0xD8;
CLKCTRL.MCLKCTRLA = 0b10000000;
PORTA.DIRSET = 0xFF;
PORTB.DIRSET = 0xFF;
PORTC.DIRSET = 0xFF;
PORTD.DIRSET = 0xFF;
PORTE.DIRSET = 0xFF;
PORTF.DIRSET = 0xFF;
while(1){
PORTA.OUTSET = 0xFF;
PORTB.OUTSET = 0xFF;
PORTC.OUTSET = 0xFF;
PORTD.OUTSET = 0xFF;
PORTE.OUTSET = 0xFF;
PORTF.OUTSET = 0xFF;
PORTA.OUTCLR = 0xFF;
PORTB.OUTCLR = 0xFF;
PORTC.OUTCLR = 0xFF;
PORTD.OUTCLR = 0xFF;
PORTE.OUTCLR = 0xFF;
PORTF.OUTCLR = 0xFF;
« Last Edit: July 10, 2019, 10:51:53 am by Simon »
  • Global Moderator
Re: ATmega4809 won't respond
« Reply #1 on: July 10, 2019, 10:54:55 am »
now working, I did nothing, very strange.
Offline westfw
« Reply #2 on: July 10, 2019, 11:25:57 pm »
I have (using MPLAB-X):
#define F_CPU (20000000/6)
 #include <xc.h>
 #include <util/delay.h>
void  __attribute__((noinline)) mydelay();
void mydelay() {
   _delay_ms(1000);
void main(void) {
    VPORTA.DIR |= 1<<7;
    while (1) {
        mydelay();
        VPORTA.IN |= 1<<7;
    return;
Which works fine, even on my home-built hardware...
Offline cv007
« Reply #3 on: July 11, 2019, 12:47:53 am »
VPORTA.IN |= 1<<7;
Looked odd to me.
I totally missed that in the datasheet (even though I know I read it).
Glad you posted that code :)
datasheet-
Writing to a bit of VPORTx.IN will toggle the corresponding bit in VPORTx.OUT.
There is the missing VPORT TGL.
Offline westfw
« Reply #4 on: July 11, 2019, 03:17:46 am »
The VPORT registers (DIR, OUT, IN) are essentially compatible with the DDR/PORT/PIN registers of the older ATmega chips.  (A good move on their part, IMO.)  (Writing 1 to the PINx register of an ATmega328 (for example) will also toggle the output.  "very old" ATmega chips (like ATmega8) do not have this feature.)
Offline cv007
« Reply #5 on: July 11, 2019, 05:05:45 am »
I was using OUTTGL for my tog() function, as I somehow equated no TGL register in VPORT to mean in wasn't there. I haven't touched an avr in a long time (mega88/168/etc), but do remember the PIN toggle.
https://github.com/cv007/ATTiny416XplainedNano/blob/master/Port.hpp
Now I feel better as it matches the rest of the pin functions, and I can save a few bytes every time I toggle an led (seems to be the only time I use toggle).
For really nice bit setting/clearing, the pic32 (I use the mm) is nice to use where almost every register is capable of set/clr/inv (every register is 32bits, and there are 4 for each).
