I have code using TC2 - WO[0] to drive a stepper clk coming out PA16
Trying to use TC4 - WO[1] on pin PA23.
Well it isn't working. The pin PB9 which also can use TC4 - WO[1] is getting clobbered even though I set it up as digital output and set up
PA23 to use peripheral number 5 -> F.
Question: If TC4 - WO[1] appears possible on multiple pins how is the correct one selected.
Are there multiple WO[1] outputs , such as one for each timer.
The data sheet says this
"Waveform output channels per TC instance 2" ( page 11 )
Leads me to believe there are two channels for each timer ??
I am using match frequency generation mode ( MFRQ).
Is there a CC0 for each timer?
Thanks
