I have been using Blinking_LED examples from the ASF on CortexM just to trace down what is going on in the chip during initialization (oscillators, PLLs, buses...). Endless layers and layers of .h includes constructed of endless #ifdef and #ifndef ... Sometimes 7 or more layers of nested #include-s just to set/clear some bit in some register.
You would need days to find out what really happens in anything not so trivial as Blinking_LED.
That being said, in comparison with reading thousands of datasheet pages for the actual chip, together with hundreds and hundreds of pages for the ARM core, ASF examples are still faster way (simply because of the absence of anything better) to (relatively) quickly grasp how to set up and use some periphery. Just use a lot of Quick find, Find in files, Goto implementation, debugger and similar functions in your IDE to track down what some ASF macro/function really does (whit the actual registers and bits) and you should be ok. The more you practice the faster you become in this.
This is the only useful purpose I found of the ASF for now. I personally would not use it for any serious projects of my own.
