At this point, my approach would be: put a scope to the ATTINY's Tx line to see what is coming out. Keep writing 'U' from the ATTINY, that would send 01010101 out plus a stop bit. (I am not highly experienced, so there is probably a ton of other better approaches.)
If nothing is coming out from ATTINY's Tx line, that means (a) you are not writing anything to the Tx line correctly, or (b) your chip probably is sick. If 'U' is coming out, I would try another letter. I like '3' which should show 00110011, but of course you can choose any other on the ASCII table. If both 'U' and '3' are coming out, chances are, your software and hardware are transmitting just fine. The issue would be baud and proper connection.
One confusing thing is, Rx of one connect to Tx of the other. The ATTINY's Tx line is what I would expect things you wrote from the ATTINY to come out, and that should got to the Rx of the FTDI. So make sure you got that correctly. My FTDI adapter would tolerate a reversed connection at least for a short time - I got them mix up every now and again. You can always say a prayer, cross your fingers, then swap Rx and Tx and see if you made that mistake.
