Author Topic: Avionics certification, and why an FPGA is an advantage?  (Read 7751 times)
Offline brucehoult
Re: Avionics certification, and why an FPGA is an advantage?
« Reply #50 on: August 19, 2026, 11:04:40 am »
Another thing is that pure logic doesn't need a clock so it doesn't need an oscillator. Crystals have a relatively high failure rate and are sensitive to vibration.
A clock doesn't imply a crystal.
If you're clocking just to make it deterministic and the clock speed is chosen with good timing slack then onboard RC clock will be fine.
Offline NorthGuy
« Reply #51 on: August 19, 2026, 12:21:15 pm »
It will not be accurate, but you can create an oscillator in FPGA fabric.
Offline free_electron
    • SiliconValleyGarage
« Reply #52 on: August 19, 2026, 03:29:40 pm »
In this application, scanning the buttons and doing everything needs to be done every 100ms or so. You could clock a CPU at 100Hz :)
The FAA's FTS (Flight Termination System) use FPGA
I think you mean NASA?
I believe it was IRIG. They have a reference design as a full Altium project. The FAA sets the criteria.
