Author Topic: AVR vs SAM3S ARM flash data retention (100 vs 10 years?)  (Read 5071 times)
Offline nazcalinesTopic starter
« on: November 11, 2014, 11:27:23 am »
Anyone know what determines the data retention spec on these micros and why they are so far off?
For AVR, the data sheet says 100 years at 25 deg Celcius.  For Atmel SAM3S (ARM cortex M3), the data sheet simply says Min 10 years.  No mention of temperature.  Is there some CYA reason why the SAM3S spec is so much lower?
Offline dannyf
Re: AVR vs SAM3S ARM flash data retention (100 vs 10 years?)
« Reply #1 on: November 11, 2014, 12:23:22 pm »
Maybe Atmel / ST know a thing or two about that?
Offline diyaudio
« Reply #2 on: November 11, 2014, 01:58:40 pm »
10 years wow thats low.
Offline David Hess
  • DavidH
« Reply #3 on: November 11, 2014, 04:03:35 pm »
It may be do to semiconductor process differences or different test methods but the later seems unlikely if they are coming from the same manufacturer.  If the AVR parts are built on an older process and the SAM3S ones on a newer denser process which seems likely, then I would believe that difference in retention time.
Offline coppice
« Reply #4 on: November 11, 2014, 04:35:11 pm »
If minimum 10 years means across the whole temperature range it might not be that far from 100 years at 25C.
Offline David Hess
  • DavidH
« Reply #5 on: November 11, 2014, 05:38:12 pm »
There is no way to really know without more data from Atmel.  Some of the newer dense floating gate processes really do have retention times that low though.
Offline coppice
« Reply #6 on: November 11, 2014, 05:45:46 pm »
Some of the flash processes for dense flash storage have retention times of just a year or two, and need regular automated refresh. Store them too long in the draw and they are dead. They are starting to look like slow DRAMs  :D  These are not the processes used for MCUs. People expect a sense of permanence from their MCUs.
Offline paulie
« Reply #7 on: November 11, 2014, 06:14:47 pm »
For really strange spec check out STM8's 100 write/erase cycles. 100 not 100 thousand.
Offline David Hess
  • DavidH
« Reply #8 on: November 11, 2014, 07:33:09 pm »
Flash embedded into a microcontroller would normally be NOR flash to provide random access but I am sure there is pressure to make it as dense as possible.
I have run across a few embedded designs now where the firmware for the microcontroller is stored in external NAND Flash and read into RAM for execution.  If they use cheap high density NAND Flash, at least they will not have to worry about tin whiskers from lead free solder causing a failure.
Do the various NAND Flash memories with embedded controllers refresh their contents while powered?
Update:
The similar Cortex M3 based microcontrollers from ST and Analog Devices specify a 10 year retention at 105C and 85C respectively so I think the lack of a temperature in the specification is just an oversight on Atmel's part and they may by 100 years at 25C.
« Last Edit: November 11, 2014, 07:47:25 pm by David Hess »
« Reply #9 on: November 11, 2014, 10:09:00 pm »
Thanks all for the replies.  I'm going to ask Atmel and will let you know their response.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #10 on: November 13, 2014, 08:31:17 am »
Flash data retention is highly depending on the environment.
- Temperature
- ESD
- (Electro)magnetic fields.
- Ionizing radiation, chips inside satellites must be very robust for this.
That's why it is important to verify flash integrity once in a while if you want a reliable application.
Some manufacturers specify a minimum retention for normal house/office conditions. Most of them don't tell you anything.
Offline coppice
« Reply #11 on: November 13, 2014, 08:49:10 am »
I don't know of any MCUs which do this automatically, but many MCUs now have marginal read detection facilities, so weak cells can be identified and pumped up by the software.
There is an inherent crystal defect problem with flash for MCUs, which means that maybe 1 in 10k devices will have a cell that leaks away rapidly. Flash MCUs for high integrity applications, like portable medical devices, tend to have some form of ECC in their flash arrays these days to help deal with this.
Offline David Hess
  • DavidH
« Reply #12 on: November 13, 2014, 03:16:51 pm »
I was asking about NAND Flash memory which includes an interface controller.  The MCUs I am familiar with all use NOR Flash and lack any sort of error detection support although I know of some exceptions which have some level of ECC support for at least RAM.
