Author Topic: AvrDudeProg5 (Successor to AVRDUDE_PROG 3.3) - GUI for AVRDude  (Read 8850 times)
Offline AVRDUDE_PROGTopic starter
  • Country: kz
    • https://yourdevice.net/
Hi everyone,
I’d like to share a project that might be useful for AVR developers. AvrDudeProg5 is a graphical user interface (GUI) for avrdude, designed to simplify flashing and configuring AVR microcontrollers. It is an upgraded version of the classic AVRDUDE_PROG 3.3 (2008).
Feedback, suggestions, and criticism are welcome! 🙂
Download Win AvrDudeProg5
Download Linux AvrDudeProg5
License:
- Freeware
System Requirements:
- OS: Windows 7/10/11, Linux
- Type: Portable (No installation required)
- Dependencies: None
- Linux/macOS: In development
Key Features:
- Visual Fuse & Lock Bit Editor: Easily configure fuses without calculating bits manually.
- Read/Write Flash & EEPROM: Simple interface for memory operations.
- Improved ATtiny Support: Fixed issues found in previous versions.
- Extensible: Easily add/edit microcontrollers, programmers, and translations via config files.
- Auto-Update: Get notified when a new version is released.
Who is it for?
- Hobbyists working with Arduino/AVR boards.
- Embedded developers who prefer a GUI over the command line.
- Anyone looking for a safe, visual way to configure fuse bits.
Languages:
Arabic (العربية), Chinese (中文), Croatian (Hrvatski), Czech (Čeština), Dutch (Nederlands), French (Français), German (Deutsch), Hindi (हिन्दी), Hungarian (Magyar), Indonesian (Bahasa Indonesia), Italian (Italiano), Japanese (日本語), Korean (한국어), Polish (Polski), Portuguese (Português), Russian (Русский), Slovenian (Slovenščina), Spanish (Español), Turkish (Türkçe), Vietnamese (Tiếng Việt).
Download & Info:
Official Website: https://yourdevice.net/
Download Page: https://yourdevice.net/projects/avrdudeprog5
YouTube Tutorials: https://youtube.com/playlist?list=PLyqq0R-QRbOcfeLSFlZ_9sPLlgI5uY2Sj
Telegram Group: https://t.me/+RfIPhxqswnJlYTUy
« Last Edit: May 01, 2026, 05:18:00 pm by AVRDUDE_PROG »
The following users thanked this post: Unixon, negativ3, coromonadalix, ledtester, neillnz, I-Like-BWRs
Offline dobsonr741
Re: AvrDudeProg5 (Successor to AVRDUDE_PROG 3.3) - GUI for AVRDude
« Reply #1 on: March 31, 2026, 01:37:18 pm »
Does it have a Claude skill version of it?
  • Country: kz
« Reply #2 on: May 01, 2026, 05:05:56 pm »
Currently, it is a standalone Windows desktop application, so there is no direct 'Claude skill' integration. However, since it acts as a GUI for AVRDude, you could technically use Claude to generate the AVRDude command line arguments for you.
I've built a Linux version. :)
Any suggestions, comments, feature requests, or criticism are welcome! 🤝
« Last Edit: May 01, 2026, 05:24:09 pm by AVRDUDE_PROG »
The following users thanked this post: coromonadalix, ledtester
Offline Doctorandus_P
« Reply #3 on: May 02, 2026, 05:07:00 am »
Do you have the source code available?
There is no way I'm going to run some binaries from an untrusted russian site.
The following users thanked this post: AVRDUDE_PROG
Offline bingo600
« Reply #4 on: May 02, 2026, 06:23:40 am »
I'll have too agree here.
Seems like a nice program, but ......
I would have to pass too.
I have been using "engbedded" for a long time to generate my avrdude command lines
https://www.engbedded.com/fusecalc/
Seems like there's a newer vers here.
https://www.engbedded.com/conffuse/
The following users thanked this post: Doctorandus_P, eugene, AVRDUDE_PROG
Offline Psi
« Reply #5 on: May 02, 2026, 07:13:31 am »
Most of the time i'm calling AVRdude inside a script, so command-line works well.
Its only really when i need to play around with fuse bits or something non-standard that a GUI is better for me.
Online voltsandjolts
« Reply #6 on: May 02, 2026, 12:26:47 pm »
AVRDUDESS works well for my simple avr needs.
https://github.com/ZakKemble/AVRDUDESS
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #7 on: May 02, 2026, 12:50:43 pm »
AVRDUDESS has been around since I was a kid. ;D
Offline coromonadalix
« Reply #8 on: May 02, 2026, 12:58:06 pm »
happy to know there is some activity  for it  and corrections and updates are made     :-+ :-+
  • Country: kz
« Reply #9 on: May 04, 2026, 04:04:21 pm »
The choice is yours. :)
  • Country: kz
« Reply #10 on: May 04, 2026, 04:17:26 pm »
It is currently in development. I'm thinking about how to keep the interface clean. Any suggestions are welcome  :)
« Last Edit: May 04, 2026, 04:19:58 pm by AVRDUDE_PROG »
  • Country: kz
« Reply #11 on: May 04, 2026, 04:47:26 pm »
You're welcome! Suggestions and recommendations are welcome. :-+
« Last Edit: May 04, 2026, 05:01:31 pm by AVRDUDE_PROG »
  • Country: kz
« Reply #12 on: May 04, 2026, 05:04:26 pm »
  • Country: kz
« Reply #13 on: May 04, 2026, 05:11:33 pm »
It's a great program. :)
Offline harp
« Reply #14 on: June 07, 2026, 10:43:30 am »
Thank you very much, I appreciate your effort.
My question / suggestion
Can the program work with a CH341A programmer and on Windows XP?
Why is there such a large difference in size between version 3.3 and version 5?
« Reply #15 on: June 15, 2026, 04:54:43 pm »
i never saw any asp or jtag built on theses 341  and for sure i myself would not use them,  avr isp asp jtag is so cheap to buy
AI friend answer
You can use a CH341A (typically configured as a USB-to-SPI/I2C/UART adapter) as a JTAG interface, but it is not natively designed for this and requires third-party patches and bit-banging.
The Challenges
No Native Hardware Support: The standard CH341A doesn't have native JTAG or SWD controller modes, meaning JTAG commands must be bit-banged via software.Signal Voltage Risks: Traditional, cheaper CH341A black modules output 5V logic. Attempting to hook a 5V signal into modern 1.8V or 3.3V JTAG processors will instantly damage the target device. Always use a version with a physical 1.8V/3.3V voltage regulator or selector switch.
Slow Speeds: Software-emulated JTAG bit-banging is extremely slow.How to Do It (The OpenOCD Route)To use a CH341A for JTAG, you will need to rely on OpenOCD (Open On-Chip Debugger).Source Code & Patches: You will need to download and compile a custom build of OpenOCD that supports the CH341A adapter, such as the widely used OpenOCD CH341A Patch on GitHub.Configuration: You will map the GPIO pins on the CH341A to the standard JTAG pins (TCK, TMS, TDI, TDO, TRST, SRST).Pin Mapping:TCK usually maps to D3TMS usually maps to D0TDI usually maps to D7TDO usually maps to D5A Better AlternativeIf you are doing serious hardware debugging, using a CH341A as a JTAG interface is widely discouraged due to the setup difficulty and risk of frying your board. Instead, developers and hardware hackers highly recommend dedicated USB-to-JTAG adapters like the FT2232H or FT232H breakout boards (e.g., Adafruit FT232H). These natively support JTAG/SWD, integrate seamlessly with OpenOCD out-of-the-box, and have built-in multi-voltage level shifting.
Offline harp
« Reply #16 on: August 31, 2026, 10:55:40 pm »
I dont know how jtag is related to avr... nor ch341a.
I ask generally if program can work with ch341a, winxp, I do flash atmega328 with ch341a with some russian software through spi... so I always like to collect alternative...
Offline Unixon
« Reply #17 on: September 01, 2026, 07:33:15 am »
Even if it would be trusted and non-russian, one update to OS and a binary is no longer running because library loader can't do shit about incompatible versions.
These are just old habits from Win95 era - thinking that the current version of Windows will last forever and a binary will also run forever and therefore no source code is needed.
There's so many dead software without sources still being used in many places, it's a huge problem.
@AVRDUDE_PROG
Seriously, man, where are the sources? The times have changed. Put it on Github.
« Last Edit: September 01, 2026, 10:13:28 am by Unixon »
Offline Unixon
« Reply #18 on: September 01, 2026, 07:34:58 am »
Are there any good offline alternatives that work just as these two?
« Reply #19 on: September 01, 2026, 09:24:03 am »
@AVRDUDE_PROG
Seriously, man, where are the source? The times have changed. Put it on Github.
Seriously  .........   no pun
If you dont like that,  you can fork your's, and or search for alternatives,   he's not under any obligations to give a source code, or host it ... if this sofware is made free ? BUT in my case if a dime is ever asked  i'm out ..
you could say the same for many softwares made for any mcu programming ... and never got published
« Last Edit: September 01, 2026, 09:26:48 am by coromonadalix »
Offline Unixon
« Reply #20 on: September 01, 2026, 10:26:01 am »
If the software is really good I would rather consider covering development costs, but with a requirement to publish it under GPL or other FOSS license.
And this is a huge problem, not only in MCU programming but in many other places too.
A lot of few decades old Windows-only "walking dead" binaries.
The following users thanked this post: abeyer, AVRDUDE_PROG
Offline Unixon
« Reply #21 on: September 01, 2026, 05:18:10 pm »
It's a small Qt app with debug symbols in the binary and it's just a small fuse calc, so I guess it wouldn't be too hard to decompile it if necessary and verify that it's safe to use.
« Reply #22 on: September 01, 2026, 05:37:40 pm »
It is an GUI  for AVRDUDE ....   all is supposed to be known and documented on how to drive it
anything can be used to build it ...  even python would not have any problems passing commands ...
Offline Unixon
« Reply #23 on: September 01, 2026, 05:54:02 pm »
I consider the fuse calc part as more important one, basically because setting wrong fuses could ruin your day and/or brick the device.
In my AVR projects I have a set of shell scripts with preprogrammed options to drive avrdude and this is not a problem at all.
However, I check fusebits like 10 times over in at least two independent calculators to make sure I'm not shooting myself in the foot.
Offline I-Like-BWRs
« Reply #24 on: September 01, 2026, 07:29:08 pm »
Thanks. This will make AVR programing eaiser. : )
