Author Topic: avrstudio7, fuses set in code, can't enter debug anymore?  (Read 4796 times)
Offline cdwijsTopic starter
« on: February 26, 2016, 04:30:14 pm »
Hi All,
I'm working with an ATMega32. Everything works fine, until I add this to my code:
#include <avr/io.h> //for fuses
FUSES =
   .high = 0x91,
   .low = 0xFF,
This triggers the error message: "error an unknown emulator error occureed debugger command leaveprogmode failed". When I remove the above lines, all is well again, and I can enter debug mode no problem, until I add the lines again.
My setup:
windows7 64bit, (microsoft windows NT6.1.7601 service pack 1 (platform win32NT))
atmel studio 7.0.634
JTAGICE mkII 0700000589B
ATmega32A
I have added the lines, hoping atmel studio would program the fuses when I start debugging. Then I have one thing less to worry about :-)
Kind regards,
Cedric
Offline cjuried
    • Juried Engineering
Re: avrstudio7, fuses set in code, can't enter debug anymore?
« Reply #1 on: February 27, 2016, 12:28:44 am »
Hi All,
FUSES =
   .high = 0x91,
   .low = 0xFF,
My setup:
ATmega32A
Kind regards,
Cedric
I let Atmel Studio set the fuses in the tool chain settings. That way I do not have to add that code manually.
Sent from my SM-G900P using Tapatalk
juriedengineering.com/
« Reply #2 on: February 27, 2016, 08:44:53 am »
Thanks cjuried, I am looking at project->properties, but I can't find a clear place to enter the fuse values. How did you do it? Is it under toolchain->AVR/GNU linker->memory settings?
Kind regards,
Cedric
Offline dannyf
« Reply #3 on: February 27, 2016, 12:22:40 pm »
It is much easier to use those predefined macros for fuse setting - read the header files for sure.
PICs are much better in this regard.
« Reply #4 on: February 27, 2016, 09:57:41 pm »
Hi Danny,
Could you send me a small project that does this? My atmel studio fails to enter debug mode, so I am doing something wrong :-)
Kind regards,
Cedric
