Author Topic: bitcloud 3.3 compile error  (Read 3462 times)
Offline Amir-AfsharTopic starter
  • Country: ir
    • fire alarm systems
« on: May 16, 2016, 08:21:30 am »
Hi friends
I downloaded BitCloud3.3 and atmel studio7.0 from the Atmel.com to finish my project, and some problems has puzzled me several days. I want to know if someone meet the same problem and solved.
1. The HADevcie application(without any change) can not build. i always get about 156 errors.Also i test other clusters, Other applications like ZLL, WSN,... downloaded from the Atmel.com have the same behavior, and the example projects download with Atmel Studio 7 are complied ok.
i tried to chagne the path of SDK, removing any space on path, decreasing the path length and so but nothing changed.
could you please help me to start by bitcloud ?
Offline sandeep.b2
  • Country: in
Re: bitcloud 3.3 compile error
« Reply #1 on: May 16, 2016, 08:52:44 am »
hi,
have u added makefile path in project properties. See image attached.
The following users thanked this post: Amir-Afshar
  • Country: ir
« Reply #2 on: May 16, 2016, 09:14:48 am »
hi
yes i attached it.
when i remove the check box of "use external make file" the errors decrease to 10, but when it checked the errors increase to 156.
Offline ataradov
    • Personal site
« Reply #3 on: May 16, 2016, 04:06:50 pm »
Please post full build output log as a text file, not screenshot.
You have to use external Makefile.
Alex
  • Country: ir
« Reply #4 on: May 17, 2016, 06:20:09 am »
Dear Friends
i decide to reinstall the windows.i refreshed the windows.
1) i don't know where i must install the Atmel Studio?
is the C:\Program Files (x86)\Atmel\Studio\ ok?
or i must install it on C:\Atmel  ??
2) in the bitcloud 3.3 i read that the recommended SDK is Atmel Studio 6.2, the question is that is there any trouble with Atmel Studio 7?
i must install which one? 7.0 or 6.2
Offline ataradov
    • Personal site
« Reply #5 on: May 17, 2016, 06:22:31 am »
Default location (Program Files) will be fine.
I would use AS 6.2 for BitCloud.
AS7 and AS 6.2 coexist without any problems, so you can install both.
Alex
  • Country: ir
« Reply #6 on: May 17, 2016, 08:58:27 am »
Dear Friends
i finally find the way to solve the trouble.
the bitcloud 3.3 must be compiled with AS 6.2, i have not any error with it.
when i build the solution with AS 7.0 i get about 165 errors.
thanks for your support
Offline ataradov
    • Personal site
« Reply #7 on: May 17, 2016, 04:18:12 pm »
It is possible that something got broken with studio updates. I have Atmel Studio 7 (Version: 7.0.634) and sample project compile just fine.
It looks like in your case it decided that all object files are already build and all is left to do is linking. I have no idea why this may happen.
Alex
Offline sandeep.b2
  • Country: in
« Reply #8 on: May 19, 2016, 06:53:57 pm »
i also had same problem. I have windows 10. So i tried it on windows 7 and it works fine.
