Author Topic: Bypass caps  (Read 17444 times)
Offline Dan MoosTopic starter
Bypass caps
« on: April 24, 2016, 10:23:57 pm »
I never seem to be able to find any good rules of thumb on bypass caps. Hoping for some hard guidelines.
Ok, it seems .1uf is the value I hear allot. Should I just slap that on everything? How does one know if that's wrong?
Ok, next, I'm currently using the atMEGA328. It has several pins for Vcc.  Would I just put one cap across the rails close to the chip still?
Ok, I'm also using an AD75019 cross point switch chip. It uses separate analog and digital rails. I feel that maybe .1uf near the digital Vcc pin, and a larger electrolytic of some sort on the analog (audio) rails would be right, but I'm really just guessing.
What about opamps? No digital there, so would you not worry unless they are noisy?
I'm assuming well regulated power supplies for all of this if it's relevant.
Finally, I plan to have a smattering of shift registers for input purposes. .1uf on each?
To summarize, how do you make these decisions? I feel the datasheet for each chip should have a suggestion, but I never see that.
Offline ataradov
    • Personal site
Re: Bypass caps
« Reply #1 on: April 24, 2016, 10:44:15 pm »
0.1 uF is a good first guess for majority of parts. The rest will come out during debugging / prototyping.
Alex
Re: Bypass caps
« Reply #2 on: April 24, 2016, 10:46:07 pm »
To each their own terminology, most call these decoupling caps, that is they decouple the devices power requirement spikes from the supply power rails as to not affect other parts of the circuit. Device datasheets usually have recommendations as to what/now much to use however as you say 0.1 uF is the most commonly used.
What one also should consider is local capacitance in addition to the bulk capacitance of the supply rail at the PSU. This is commonly seen on PCB's that are remote to the PSU and need be from only a few uF's to a 100 or so.
Occasionally you'll see Tantalums used for local capacitance as they have better high speed spike performance than electrolytics.
Power rail trace impedance is also important as to not allow droop when demands are great, this also helps reduce induced noise from devices affecting rails.
Good rule of thumb is 0.1 uF for any/all IC's.
Avid Rabid Hobbyist
Offline jacobfeder
Re: Bypass caps
« Reply #3 on: April 24, 2016, 10:54:19 pm »
Dave gives a pretty good explanation of this:
For really high performance using multiple bypass capacitors with progressively smaller values can decease the total impedance at higher frequencies since larger capacitors will have larger series inductance. This is also explained in the video.
Offline Someone
    • send complaints here
Re: Bypass caps
« Reply #4 on: April 24, 2016, 11:11:57 pm »
Murata have a lot of detail in their data, including selection criteria:
http://www.delorie.com/pcb/smd-challenge/pdfs/murata-01005.pdf
Bypass is simply determining what frequencies need to be supported/suppressed and selecting a low enough impedance capacitor to achieve this. Looking at the impedance vs frequency plots the descending line is proportional to the capacitance, and then for a given capacitance the resonance (beyond which the impedance increases again) is a function of the capacitor size/package. 100nF was common decades ago, 1uF parts have seen strong competition and are often a better choice.
Offline westfw
Re: Bypass caps
« Reply #5 on: April 25, 2016, 11:30:58 pm »
I think the general rule-of-thumb is "one 0.1uF cap for each power pin on the chip, unless it says different in the datasheet."
So your m328 gets two 0.1uF caps (rule) and an additional cap on Aref (datasheet.)
A fair number of newer microcontrollers have built-in regulators for a Vcore lower than Vio, and need a more significant filter cap at the output of the regulator.
What I haven't been clear on is the impact of small multilayer ceramic chip caps.  There has always been this background thought that "even more capacitance would be good, but as you get larger than 0.1uF you start to get into packages and technologies (film, electrolytics) that have higher lead inductance that defeats any value you'd get from the higher capacitance."  Well, that was fine back in the old days when 0.1uF was a pretty big disk cap, but I don't see that a 10uF 0805 SMT cap has higher lead inductance than a 0.1uF 0805 SMT cap, so I've been wondering if I can reduce my BOM by using the same 10uF caps I needed for my regulator output for by bypass caps too...
Offline uncle_bob
Re: Bypass caps
« Reply #6 on: April 25, 2016, 11:44:22 pm »
Hi
If you take a look at costs and package sizes, in a good dielectric (X7R) 0.1 uf is a reasonable part. That as much as anything else makes it a commonly recommended item. Of course there is some feedback there as well. Everybody buys 0.1 uf so the volume goes up and the price comes down.
Doing a board with a power plane, ground plane, and 0.1 uf on each power pin is a pretty good way to start. You will probably need some bulk capacitance somewhere on the planes. You may also need some minimum capacitance to keep your regulators happy.
Bob
Offline Someone
Re: Bypass caps
« Reply #7 on: April 26, 2016, 03:06:57 am »
It can depend on the specific series of capacitor and how the electrodes are arranged (and if the height of the part is different for different capacitances), but you can compare the published data on the same series+size from (TDK and Samsung have per part characterisation data on Digikey). Generally I put the largest cost effective capacitance into each footprint for bypassing.
Offline uncle_bob
Re: Bypass caps
« Reply #8 on: April 26, 2016, 11:26:42 am »
Hi
Dielectric material matters a *lot* in terms of capacitor performance. Going from 0.1 uf to 10 uf in the same (small) package generally requires you to go to a less desirable dielectric ( = it does not perform as well). This along with inductance issues will quickly get you ...
Bob
Offline MT
  • Country: aq
Re: Bypass caps
« Reply #9 on: April 26, 2016, 12:40:02 pm »
Many multilayer ceramic caps changes its capacitance due to voltage applied.And as usually with that comes other parameters that changes.
For low power analog every 5th or even 10th IC a 100nF, but usually i sprinkle 100nF and 10u here and there, wherever i have space if its a large PCB. But as usual it all depends on your overall design.
« Last Edit: April 26, 2016, 12:46:32 pm by MT »
Offline harry4516
    • www.dj0abr.de
Re: Bypass caps
« Reply #10 on: April 27, 2016, 12:27:51 am »
0.1uF for each Vcc pin is a good rule.
But be warned, I have seen many layouts where the Vcc line goes to the pin and then to the 0.1uF cap. This can cause any kind of problems especially with analog ICs even if the distance is very small.
The Vcc line must first go to the cap and then to the IC pin.
For ATmegas with 3 Vcc pins I use three caps. Only in very simple applications (i.e. without using the ADC) you can use one cap and connect all vcc pins directly together.
« Last Edit: April 27, 2016, 12:29:43 am by harry4516 »
Offline Someone
Re: Bypass caps
« Reply #11 on: April 27, 2016, 03:14:37 am »
Hi
Bob
I've been through a lot of capacitor ranges recently, for the common 100n and 10uF in 0805 you'll be comparing X5R or X7R options in both, class 1 bypassing even at 100nF would be very unusual. Its the voltage rating that will vary considerably (going from a series stack to a parallel stack) but as I said you just need to pull the data for the target caps and compare them yourself.
Offline uncle_bob
Re: Bypass caps
« Reply #12 on: April 27, 2016, 10:42:43 am »
Hi
Bob
Hi
If you start of in 0402 with your 0.1 uf caps and then to looking for 10 uf the dielectric will change (if you can even find them). Same thing is true in 0603. It's been a *long* time (20 years) since we used 0805 bypass caps at 0.1 uf.
Bob
Offline jnz
Re: Bypass caps
« Reply #13 on: April 27, 2016, 02:49:22 pm »
Bob,
What are the issues with using 0805 for .1uF caps? Obviously it seems 0402 and 0603 are smaller and easier to route around but if you have a hand assembled board and have almost entirely 0805 components, is it worth switching to the smaller parts for the supply caps?
Offline Someone
Re: Bypass caps
« Reply #14 on: April 28, 2016, 12:07:13 am »
Bob,
The lower lead impedance (much lower inductance) is an advantage if you can fit the traces/vias and chip pins to take advantage of it.
Hi
Bob
Hi
Bob
See how the poster quoted was taking about 0805.... so the comparisons were with 0805.
Offline uncle_bob
Re: Bypass caps
« Reply #15 on: April 28, 2016, 10:26:18 pm »
Bob,
Hi
The original comment was in reply to an 0805 based previous post. As your package size goes up, the range of capacitance you can get also goes up.
With modern IC's you get fast edges. That's simply a function of the processing of the IC. Small geometry = fast edges (at least internal to the chip). Yes, there are a few assumptions there.
The smaller the bypass cap, the closer you can get your vias together. (You do put one to ground and Vcc planes at each cap don't you??). The current in one via should be equal and opposite to the current in the other via. The closer they are together, the more the via inductance will cancel out. The smaller cap probably will measure out as having a higher SRF even without via's involved. So, provided the dielectric continues to perform to high frequencies, smaller is better.
What makes things even more appealing is that the smaller parts do fit into the layout easier. They also seem to cost less, at least in the quantities we buy them in.
Bob
Offline westfw
Re: Bypass caps
« Reply #16 on: April 29, 2016, 01:31:56 am »
No.  Usually I have a two-layer or even one-layer board, and a separate ground and vcc planes are expensive luxuries that I might get to sometime later, if I get to a 'really complex' design...
Offline jnz
Re: Bypass caps
« Reply #17 on: April 29, 2016, 04:40:02 am »
Good info here, but now the big question... How to route. I've seen even recently BOTH of these options shown with people saying the other was the worse one.
Pic showing two options.
So... Is it better to have the via<>cap<>micro  or  cap<>via<>micro???
I've seen it people opine about preference, how vias directly to the micro with the cap near but only on traces is actually decoupling, but may allow for switching noise where as bla bla bla...
What is the actual right way to route? I've always thought via cap micro made sense but what do I know!? Is the image shown an option? What to do if you need the cap on the other side of the board?
Offline TiN
  • Country: ua
    • xDevs.com
Re: Bypass caps
« Reply #18 on: April 29, 2016, 04:57:57 am »
In general via>cap>IC pin is the best, given all the other constrains same. Purpose of MLCC there to provide HF power for IC switching pulses, hence you want lowest inductance and resistance from IC pin to cap. That's true for most of digital/mixed designs, in generic cases. Sometimes it's not good, even cap nearby is not good (e.g. LT3042 LDO input power decoupling, read it's datasheet ;).
Always check what are your IC reference designs suggest and recommend.
I tend to overengineer things if time allow and route connections in small wide shapes from via to decoupling and to pins, instead of tiny traces. ;)
Offline Kleinstein
Re: Bypass caps
« Reply #19 on: April 29, 2016, 07:18:16 pm »
Using the via - cap - IC version gives less noise to the supply and the IC. So this is normally the preferred version. However if something like ground bounce is critical (e.g. some ADCs), the version cap - via - IC can be better,  for the GND pins.
Usually if 100 nF don't work, you have to look more careful and a simple rule of thumb is not working anymore. Higher power chips like line drivers and voltage regulators might need more than 100 nF - low power chips usually not.
Offline Someone
Re: Bypass caps
« Reply #20 on: April 30, 2016, 09:10:39 am »
The first (of more to come?) capacitance roundup is attached. Digikey pricing for in stock reels of various capacitances in various packages.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Bypass caps
« Reply #21 on: April 30, 2016, 12:52:06 pm »
Above graphs use metric sizes?
The following users thanked this post: audi95
Offline uncle_bob
Re: Bypass caps
« Reply #22 on: April 30, 2016, 02:42:36 pm »
No. It's in inch. Who use metric in chip passive sizes? AFAIK everyone in the business uses imperial units on chip passives.
Hi
If it is inch sizes, I would have expected to see: 0201, 0402, 0603, 0805, 1206 and so on. With the exception of 0603, I don't see the sizes I would expect if it's inches. Since 0603 is 0201 in metric, it would show up on both lists. Those look like metric sizes to me.
Bob
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Bypass caps
« Reply #23 on: April 30, 2016, 07:57:37 pm »
Note to any engineer. Always specify units. Even if you're using standard iso units.
Offline timb
    • timb.us
Re: Bypass caps
« Reply #24 on: April 30, 2016, 08:11:07 pm »
Here's pretty much all you could ever want to know about bypass caps, from Murata: http://www.murata.com/~/media/webrenewal/support/library/catalog/products/emc/emifil/c39e.ashx
The following users thanked this post: jnz
