Author Topic: C code now doesnt seem right on MPALB X IDE V3.61  (Read 1126 times)
Offline ocsetTopic starter
« on: March 08, 2018, 09:40:35 am »
Hello,
Please advise why this code is now full of "unable to reslove identifier LATA0"  etc etc , error messages.
This code was fine before.
It was running fine on the micro
I am sure i did not get such errors before.
Its XC8 C  for PIC16F18856
//pwm dimming
//PIC16F18856
//XC8 compiler
//MPLAB X V3.61
//date 10 oct 2017
// PIC16F18856 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FEXTOSC = OFF    // External Oscillator mode selection bits (Oscillator not enabled)
#pragma config RSTOSC = HFINT1  // Power-up default value for COSC bits (HFINTOSC (1MHz))
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config CSWEN = OFF      // Clock Switch Enable bit (The NOSC and NDIV bits cannot be changed by user software)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (FSCM timer disabled)
// CONFIG2
#pragma config MCLRE = OFF      // Master Clear Enable bit (MCLR pin function is port defined function)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)
#pragma config LPBOREN = OFF    // Low-Power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = ON       // Brown-out reset enable bits (Brown-out Reset Enabled, SBOREN bit is ignored)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices)
#pragma config ZCD = OFF        // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR.)
#pragma config PPS1WAY = OFF    // Peripheral Pin Select one-way control (The PPSLOCK bit can be set and cleared repeatedly by software)
#pragma config STVREN = OFF     // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will not cause a reset)
// CONFIG3
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT operating mode (WDT Disabled, SWDTEN is ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4
#pragma config WRT = OFF        // UserNVM self-write protection bits (Write protection off)
#pragma config SCANE = not_available// Scanner Enable bit (Scanner module is not available for use)
#pragma config LVP = OFF        // Low Voltage Programming Enable bit (High Voltage on MCLR/Vpp must be used for programming)
// CONFIG5
#pragma config CP = OFF         // UserNVM Program memory code protection bit (Program Memory code protection disabled)
#pragma config CPD = OFF        // DataNVM code protection bit (Data EEPROM code protection disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <stdint.h>
#define  _XTAL_FREQ 4000000
    uint8_t   count;
    uint8_t   count1;
    uint8_t   count2;
void main(void) {
    //Setup ports
        TRISA = 0x30;   //ADC INS
        TRISB = 0x08;    //ZCD & DALIRX..really 0x09
        TRISC = 0x00;   //SELECT
        ANSELA = 0x00;   //ADC INs
        ANSELB = 0x00;
        ANSELC = 0x00;
        WPUA = 0x00;
        ODCONA = 0x00;
        SLRCONA = 0x00;
        INLVLA = 0x00;      //ST?
        CCDPA = 0x00;
        CCDNA = 0x00;
        WPUB = 0x00;
        ODCONB = 0x00;
        SLRCONB = 0x00;
        INLVLB = 0x00;      //ST?
        CCDPB = 0x00;
        CCDNB = 0x00;
        WPUC = 0x00;
        ODCONC = 0x00;
        SLRCONC = 0x00;
        INLVLC = 0x00;      //ST?
        CCDPC = 0x00;
        CCDNC = 0x00;
        INTCON = 0x00;
        CM1CON0 = 0x00;
        CM1CON1 = 0x00;
        CM2CON0 = 0x00;
        CM2CON1 = 0x00;
        PWM6CON = 0x00;
        PWM7CON = 0x00;
        ZCDCON = 0x00;
        //Initialize ports
        LATAbits.LATA0 = 0;
        LATAbits.LATA1 = 0;
        LATAbits.LATA2 = 0;
        LATAbits.LATA3 = 0;
        //LATAbits.LATA4 = 0;     temp sensor input
        //LATAbits.LATA5 = 0;     light sensor input
        LATAbits.LATA6 = 1;     //vmf pin FET
        LATAbits.LATA7 = 0;
        //LATBbits.LATB0 = 0;      zero crossing input
        LATBbits.LATB1 = 0;
        LATBbits.LATB2 = 0;         //dali TX pin
        //LATBbits.LATB3 = 0;       dali RX pin
        LATBbits.LATB4 = 0;
        LATBbits.LATB5 = 0;
        LATBbits.LATB6 = 0;
        LATBbits.LATB7 = 0;
        LATCbits.LATC0 = 0;
        LATCbits.LATC1 = 0;       //pwm dim
        LATCbits.LATC2 = 0;     //pulldown resistor not fitted
        LATCbits.LATC3 = 0;     //pulldown resistor not fitted
        LATCbits.LATC4 = 0;
        LATCbits.LATC5 = 0;
        LATCbits.LATC6 = 0;
        LATCbits.LATC7 = 0;
    //5 second delay
    for (count=1;count<=10;count++)   {
    __delay_ms(10);
    LATCbits.LATC1 = 0;
    __delay_ms(30);
    LATAbits.LATA6 = 0;
    __delay_ms(30);
while(1){
        LATCbits.LATC1 = 0;
        __delay_us(10);
        LATCbits.LATC1 = 1;
        __delay_us(20);
    return;
Offline BNElecEng
Re: C code now doesnt seem right on MPALB X IDE V3.61
« Reply #1 on: March 08, 2018, 10:17:49 am »
I've copied your code and compiled it without any issues.
I'm using MPLAB X IDE 4.01 with XC8 compiler version 1.45
I did not make any changes, just created a new project with your code as the main.c source file.
The following users thanked this post: ocset
Offline Wilksey
« Reply #2 on: March 08, 2018, 06:42:12 pm »
Make sure you have the right chip selected, most 16F chips don't support the LAT part of the port, that is the only thing that I can think of that would cause that issue, looks like the xc.h file is included, I usually put it before all of the config defines, not that it should make a difference to finding the LAT definition.
