Author Topic: Verilog, binary to Gray code converter  (Read 5344 times)
Offline sevenofnine33Topic starter
  • Country: cs
« on: May 14, 2018, 03:48:22 pm »
Not sure if this is the section to ask, but I am a beginner and don't know much, so I would appreciate the help.
I am designing a binary to Gray code converter. This is my main code:
module gray_code (bin_num, Gray_num);
input [3:0] bin_num; //binary input
output [3:0] Gray_num; //gray output
assign Gray_num[3] = bin_num[3];
assign Gray_num[2] = bin_num[3]^bin_num[2];
assign Gray_num[1] = bin_num[2]^bin_num[1];
assign Gray_num[0] = bin_num[1]^bin_num[0];
endmodule
And this is testbench:
module gray_code_tb;
reg [3:0] bin_num;
wire [3:0] Gray_num;
integer i;
gray_code DUT(.bin_num(bin_num),.Gray_num(Gray_num));
initial begin
for(i=0;i<16;i=i+1)begin
    bin_num=i;
    $display("BIN = %b   GRAY =%b", bin_num, Gray_num);
end
end
endmodule
The output I get after simulation is:
BIN = 0000   GRAY =xxxx;
BIN = 0001   GRAY =xxxx;
BIN = 0010   GRAY =xxxx;
BIN = 0011   GRAY =xxxx;
Why is it showing all x for Gray code?
  • Country: cs
Re: Verilog, binary to Gray code converter
« Reply #1 on: May 14, 2018, 04:04:26 pm »
Found the problem. In my simulation the time didn't pass. Adding #50 after bin_num=i fixed it.
