Author Topic: Can I erase flash on locked MCU?  (Read 3848 times)
Offline SpiroTopic starter
  • Country: cs
« on: May 06, 2013, 12:08:25 pm »
I have around 15 MSP430F2013 from Hanla level sensors and I want to recycle them.
And this MCU have slow 16bit ADC. I presume they are locked. I downloaded pdf
about this MCU but I don't cant find anything about erasing already locked MCU.  :-//
I have also Renesas MCU from car radio
Why? Why not. Why I should throw away MCU if it can be recycled? Earth is already
f**** up place.
Online jahonen
Re: Can I erase flash on locked MCU?
« Reply #1 on: May 06, 2013, 01:28:26 pm »
I think MSP430 has OTP protection which physically disconnects JTAG/SBW connection inside MCU, so I think it can't be reused if JTAG fuse has been blown.
Regards,
Janne
  • Country: cs
« Reply #2 on: May 06, 2013, 03:53:01 pm »
Yes I saw that but there is some other type of programming (bootstrap, serial something?).
Online nctnico
« Reply #3 on: May 07, 2013, 12:13:16 am »
AFAIK the serial bootstrap is also disabled when the fuse is blown. Another thing to beware of is that some of the smaller MSP430 don't even have the serial bootloader.
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: May 07, 2013, 02:03:38 am »
Those MSP430s are really cheap anyways.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline amyk
« Reply #5 on: May 07, 2013, 11:00:02 am »
You presume they're locked but why not throw them on the programmer to make sure? Maybe you'll get lucky, you never know until you try.
Those MSP430 have a physical fuse so it's not like the common "erase the chip and it's ready for reuse" case. On the other hand, that might make it even easier to attack the protection --- decap and look for the blown fuse, then restore it with microwiring techniques. Physically damaged areas will stand out a lot more on a die photo than EEPROM cells.
As for the Renesas, it depends on the model. Some have permanent protection, others don't.
