The description for Event ID 10997 from source MsiInstaller cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Product: Microsoft Visual Studio 2010 Shell (Isolated) - ENU -- Error 997.Overlapped I/O operation is in progress.
(NULL)
(NULL)
(NULL)
(NULL)
(NULL)
the message resource is present but the message is not found in the string/message table
If you have hacks on hacks on your machine then it's clearly time for full reinstall.
Other than that I'd say download the latest installer and try with that.
7.0 doesn't work as mentioned.
Full reinstall would take way, way more time to get back into an operating condition. Are you volunteering your time and effort to record all my installed programs and configurations, and put them back as they are now? Didn't think so...
The fix of this issue is to rename c:\program data\microsoft\crypto\RSA\S-1-5-18 and try re-installation of .net again.
TimIt's an investment into all those next times you don't have to muck about and a nice clean-up to boot.
Regarding reinstalling:
Now that I feel better.....I also stumbled on thisQuoteThe fix of this issue is to rename c:\program data\microsoft\crypto\RSA\S-1-5-18 and try re-installation of .net again.
Ignore the .net part of course
You can go for AVRStudio v7.0.1188 (it's a direct link), which was the last ATMEL release before Microchip started overbloating -the already bloated- AS7 with their own garbage since AS v7.0.1417...
You could always use a second disk drive for dual boot or a virtual machine.
How much would you quote for that? $1000? I'll do that right now, if you come over here and deliver within 3 days (seems reasonable) what I've described!
S-1-5-18, as the name suggests, is owned by SYSTEM. That sounds like a very bad idea.
Nope, needs twice the C: space I have (and that's not counting the breathing room Windows already uses on a regular basis). Also says I need KB3033929, which... sounds like something I should already have installed, but I don't actually see it in the list? (FYI, I don't screw with Windows Update, except one time, to remove that stupid Win10 upgrade BS. Nothing old is showing as pending.)
Sometimes a large amount of space on C: is taken in the user profile by things that could be moved elsewhere.
There are several way to free up space in the profile (of course if you have the space on another disk!):
So I want to poke an AVR8. Simple enough, right? Checklist: GCC, headers, whatever chip-specific configs are needed, an IDE or editor, and programmer and drivers.
