Author Topic: chipKIT DP32 bootloader source ZIP  (Read 1064 times)
Offline Jacques LouwTopic starter
« on: June 18, 2026, 02:01:06 pm »
Hi, can anybody help or share with me the full "chipKIT DP32 bootloader source ZIP" files? I can't track a surviving copy down from the net please.
Offline JacobChrist
    • pontech.com
Re: chipKIT DP32 bootloader source ZIP
« Reply #1 on: June 19, 2026, 07:13:23 pm »
The git repo is here for most of the chipKIT boards.  I'm not sure if the DP32 specifically is in this repo:
https://github.com/chipKIT32/PIC32-avrdude-bootloader
I think you can build all the bootloaders with the free version of MPLAB but some bootloaders will not fit in the boot area of flash without the paid optimized version.
Some Digilent boards shipped with a version of the bootloader that was not open source (just a warning that your board may not work the same with the open source version).  The specific case I found was that the ethernet module in must be configured in the bootloader.  The Max32 bootloader did this, but the open source version did not.
Jacob
