A quick web search brings up the
Chisel page at Berkeley, and followed links to a
user's guide of sorts.
Now, I do VHDL daily, and I've done Verilog in the past, and as a hardware/FPGA engineer I looked to see whether Chisel supports the usual constructs. I also looked to see how it works as a simulation/verification language. Also, I've noted in this thread that many people assume that writing VHDL (or Verilog) is somehow akin to writing in assembly for a processor. That's really not true at all. (If you want an example of VHDL-as-assembly-code, look at the Xilinx PicoBlaze code, which is nothing more than instantiations of the LUTs with INIT values and flip-flop primitives.)
My current work involves data paths from multiple ADCs, with some processing on samples, and pushing those samples into block RAMs for re-organization prior to being shipped out over a communications link. There is also a lot of "other" stuff required, such as a command/data uplink, a command parser, a mechanism to store parameters in off-FPGA non-volatile storage, SPI control of DACs for setting biases and control of ADCs for housekeeping. I think this sort of design is where FPGAs excel, and it's probably the most common sort of FPGA design. There is no sequential-execution processor in this part of the design. (Sensor data go to and commands come from a remote box with a processor, but that's because the processor is well-suited to managing an Ethernet interface.) A current design has three clock domains.
So, with that. I looked at examples for describing synchronous logic, since that's the basis of digital logic design. We're all familiar with VHDL's process and Verilog's always blocks, both of which make clear which signal is the clock, which is an async reset, and so forth. The examples
here are, honestly, baffling. None of the examples seem to make clear which clock and which reset are used. Maybe I'm missing something, maybe there's a mechanism to indicate "all of these signals are clocked by this and reset by that," but I can't find it.
I assume that it can infer adders and multipliers, based on operators.
There appears to be a very simply method of instantiating memories, with both synchronous and asynchronous reads.
It has a mechanism similar to a VHDL generic that allows one to pass a, well, generic, down to an instantiated entity where it can be used as a constant or as a thing to select.
There is a thing called BlackBox which allows the designer to hopefully instantiate device-specific hardware, such as high-speed serializers and deserializers or input and output DDR registers and clock PLLs and DLLs, all of which are necessary for real designs. It might be useful to see an example of how Chisel would handle the instantiation of a Xilinx DCM and how it can use that module's outputs to clock various logic parts.
That Chisel seems to think tristates are not important is puzzling -- sure, inside an FPGA we cannot use them, but at the I/O they're used all the time.
That I can't tell what logic is synchronous and what is combinatorial strikes me as somewhat dangerous. You know, the whole Cliff Cummings "Styles that kill" thing, where you can write Verilog with blocking and non-blocking assignments. Hell, looking at the Chisel examples, I can't tell if there's any sort of delta timing model involved.
They admit that for non-trivial test benches you should use Verilog.
OK. That there is a RISC-V implementation written in Chisel is interesting. But what I want to understand is: why is Chisel "better" than VHDL or Verilog/System Verilog? It looks simultaneously verbose yet
Part of what makes VHDL "Verbose" is that you have to specify things like the clock and the reset and which edge of the clock is used for the logic and all of that. A person looking at the code wants to know that stuff. And then we can hide it all by putting it into an entity and verifying the entity is correct, and then instantiating the entity where it is needed.
Chisel has software-based concepts such as inheritance and classes (there's an example which starts with
class StackPointer(size:Int) extends Module { ) but are those useful in hardware designs?
Anyways, these are just my first-order thoughts. There are things about the standard HDLs that work well, and things that can be annoying, and we all know the line about "the languages were originally for simulation and modeling with synthesis an afterthought." But, sheesh, it's been over 30 years for VHDL and likely that same amount of time for Verilog, and it is obvious that both languages have evolved to the point where they that "original" concept is obsolete. A competent engineer can write correct descriptions of the intended synthesizable logic and then turn around and write comprehensive test benches (that take advantage of non-synthesizable constructs) in either language.
Or, tl;dr: tell me why Chisel (or, really, any potential new HDL) is significantly better for hardware design and verification than the incumbents, and please don't bullshit me.
