Author Topic: Unable to get waveform when using Simulator-Logic Analyzer MPLabXIDE V5.4  (Read 2137 times)
Offline abrarbaigTopic starter
  • Country: sa
Hello. I am using MPLAB XIDE V 5.4, to using XC-32 compiler for PIC D/IO. I am using its simulator-Logic Analyzer to view output (Digital I/O). I was able to get the output in the previous version 5.05. Any idea how to get the output?
Offline lluchiari
  • Country: br
Re: Unable to get waveform when using Simulator-Logic Analyzer MPLabXIDE V5.4
« Reply #1 on: December 17, 2020, 08:07:43 pm »
I'm having the same problem here. I guess this new versions changes (from 5.35 ahead) are causing all those troubles (migrating to x64 and change java platform).
I tried to debug some problems, but it's something on source code. One interesting problem I had was with XC-8/xc-16 new versions with MpLAB. I dont know why I couldn't reconfigure my project, nor compile. Now I'm using MPLAB IDE v5.40 and XC8/16 version 2.10. The only problem is the simulator itself.
« Last Edit: December 17, 2020, 08:15:10 pm by lluchiari »
Offline lluchiari
  • Country: br
« Reply #2 on: December 17, 2020, 09:04:53 pm »
There's a new version...5.45, but still have problem.
I re-intalled 5.20 and is working!
