Well if you have the WeAct CH32X035 core board you just press the BOOT key while plugging in the USB cable, that boots the chip in its bootloader.
In WCHISP studio you select the CH32X035F8U6 and as "Dnld Port" you set "USB". Then you click "Deprotect" as soon as the chip is recognized by WCHISP studio.
On the CH32X035 the boot select pin is actually the USB DP, and to enter boot mode you have to pull-up the pin via a 5k (ish) resistor to 3.3V.
