As long as the USB interrupts are not blocked for longer than the allowed USB request time-out, there's no reason you should have a problem.
The problem is that the USB ISR calls the SPI2 code which then talks to the serial flash - all inside the ISR.
As long as the USB interrupts are not blocked for longer than the allowed USB request time-out, there's no reason you should have a problem.The USB device needs to be ready to handle setup requests or data requests (even if just to NAK them) which can be issued by the host at any time.
Please point me to an USB device implementation which won't NAK a busy endpoint in hardware. In other words, you don't need software/interrupt handling for the NAKs alone.
Yes, of course. But you have to tell the hardware to NAK automatically by some bit setting.
but I'd be very surprised if any of them would not start NAKing automatically after transmitting/receiving a single packet (or FIFO exhaustion), until further software handling.
Evidently, on Windows at least, disabling the USB global interrupt doesn't break anything
So it is certainly not the case that after 3ms it bombs out.
I am happy to try to do this differently, and for sure the "correct" solution ought to be to return some sort of "try again in a while" status because that must be what all the $3 USB-serial converters must be doing
Just making the ISR very short is trivial: copy the 512 byte sector into a buffer, and return USBD_OK. An RTOS task can then write the flash. The "slight problem" is that the host will be back in well under a millisecond, trying to write the next one
As I've said, I would handle things at the endpoint level. While host may still decide to be impatient and time out, the general wait mechanism in USB at data packet level is the NAK mechanism (see USB 2.0 5.3.2, An endpoint can inform the host that it is busy by responding with NAK. NAKs are not used as a retire condition for returning an IRP to a software client. Any number of NAKs can be encountered during the processing of a given IRP. A NAK response to a transaction does not constitute an error and is not counted as one of the three errors described above.) This appears to be widely accepted by hosts and drivers therein. It means, that you don't re-enable an Out endpoint for Rx (or don't write data for Tx to In endpoint and enable it) until whatever transaction with the slow memory is finished, using whatever mechanism (e.g. buffering and leaving the USB interrupt, the transaction to be finished by "main" or RTOS later); attempts of host to send more data to Out endpoint or to poll In endpoint are NAKed by the USB hardware of device.
Yes, this is not something you can click in Cube or fix by adding a few selected lines. Cube, as any library, inevitably caters only for a miniscule fraction of all possible usage cases, arguably the "most common" ones. OTOH, Cube is not the only option. There are open-source and third-party solutions out there, and there are consultants available.
Plus a bug which has been there for years, which we fixed today and which many others must have fixed before but never told anybody.
