Author Topic: Common Flash Interface  (Read 3616 times)
Offline desowinTopic starter
« on: October 05, 2011, 06:28:21 am »
Does anyone know where the AMD/Fujitsu command set for CFI can be found?
What is the mysterious K8D1x16U mode in K8D3216UBC datasheet?
Does anyone know if the device can be protected/unprotected without using the Vid (high voltage)? (that is, whether it can be protected/unprotected through the CFI or any other way)
EDIT: I managed to use the High Voltage temporary block protection removal in the particular case - I posted detailed instructions on my blog.
« Last Edit: October 19, 2011, 10:09:14 am by desowin »
