Author Topic: compiler issues  (Read 3404 times)
Offline m3vuvTopic starter
compiler issues
« on: December 13, 2020, 03:03:32 am »
hi all,im trying to load this into a uno but get these errors,any ideas what is wrong?
#include<JC_Button.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const float Low_BAT_level = 3.0;
//Current steps with a 3R load (R7)
const int Current [] = {0,100,200,300,400,500,600,700,800,900,1000};
const byte PWM_Pin = 10;
const byte Buzzer = 9;
const int BAT_Pin = A1;
int PWM_Value = 0;
unsigned long Capacity = 0;
int ADC_Value = 0;
float Vcc = 4.28; // Voltage of Arduino 5V pin ( Mesured by Multimeter )
float BAT_Voltage = 0;
float sample =0;
byte Hour = 0, Minute = 0, Second = 0;
bool calc = false, Done = false;
Button UP_Button(2, 25, false, true);
Button Down_Button(3, 25, false, true);
void setup () {
Serial.begin(9600);
pinMode(PWM_Pin, OUTPUT);
pinMode(Buzzer, OUTPUT);
analogWrite(PWM_Pin, PWM_Value);
UP_Button.begin();
Down_Button.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(2);
display.setCursor(12,25);
display.print("EASY TECH");
display.display();
delay(2000);
display.setCursor(2,15);
display.print("Adj Curr:");
display.setCursor(2,40);
display.print("UP/Down:");
display.print("0");
display.display();
//************************* End of Setup function *******************************
void loop() {
  UP_Button.read();
  Down_Button.read();
if (UP_Button.wasReleased() && PWM_Value < 256 && calc == false)
  PWM_Value = PWM_Value + 25;
  if(PWM_Value > 256){
    PWM_Value=PWM_Value-25;
  analogWrite(PWM_Pin,PWM_Value);
  display.setCursor(2,25);
  display.print("Curr:");
  display.print(String(Current[PWM_Value / 25])+"mA");
  display.display();
  Serial.println(String(Current[PWM_Value / 25]));
  Serial.print(PWM_Value);
if (Down_Button.wasReleased() && PWM_Value > 1 && calc == false)
  PWM_Value = PWM_Value - 25;
  display.display();
  Serial.println(String(Current[PWM_Value / 25]) + "mA");
if (UP_Button.pressedFor (1000) && calc == false)
  digitalWrite(Buzzer, HIGH);
  delay(100);
  digitalWrite(Buzzer, LOW);
  timerInterrupt();
//************************* End of Loop function *******************************
void timerInterrupt(){
  calc = true;
  while (Done == false)  {
     Second ++;
    if (Second == 60)  {
      Second = 0;
      Minute ++;
    if (Minute == 60)  {
      Minute = 0;
      Hour ++;
 //************ Measuring Battery Voltage ***********
  for(int i=0;i< 100;i++)
   sample=sample+analogRead(BAT_Pin); //read the Battery voltage
   delay (2);
  sample=sample/100;
  BAT_Voltage = sample * Vcc/ 1024.0;
    display.setCursor(20,5);
    display.print(String(Hour) + ":" + String(Minute) + ":" + String(Second));
    display.setTextSize(1);
    display.setCursor(0,25);
    display.print("Disch Curr: ");
    display.print("Bat Volt:" + String(BAT_Voltage)+"V" );
    Capacity =  (Hour * 3600) + (Minute * 60) + Second;
    Capacity = (Capacity * Current[PWM_Value / 25]) / 3600;
    display.setCursor(2, 55);
    display.print("Capacity:" + String(Capacity) + "mAh");
    display.display();
    if (BAT_Voltage < Low_BAT_level)
      display.print("Capacity:");
      display.print(String(Capacity) + "mAh");
      display.display();
      Done = true;
      PWM_Value = 0;
      delay(100);
      delay(100);
      delay(100);
      delay(100);
       delay(1000);
i get these errors:Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
sketch_dec13a:180:1: error: expected unqualified-id before numeric constant
 1
sketch_dec13a:371:13: error: redefinition of 'const float Low_BAT_level'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:13:13: note: 'const float Low_BAT_level' previously defined here
sketch_dec13a:373:20: error: redefinition of 'const int Current []'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:15:11: note: 'const int Current [11]' previously defined here
sketch_dec13a:374:12: error: redefinition of 'const byte PWM_Pin'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:16:12: note: 'const byte PWM_Pin' previously defined here
sketch_dec13a:375:12: error: redefinition of 'const byte Buzzer'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:17:12: note: 'const byte Buzzer' previously defined here
sketch_dec13a:376:11: error: redefinition of 'const int BAT_Pin'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:18:11: note: 'const int BAT_Pin' previously defined here
sketch_dec13a:377:5: error: redefinition of 'int PWM_Value'
 int PWM_Value = 0;
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:19:5: note: 'int PWM_Value' previously defined here
 int PWM_Value = 0;
sketch_dec13a:378:15: error: redefinition of 'long unsigned int Capacity'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:20:15: note: 'long unsigned int Capacity' previously defined here
sketch_dec13a:379:5: error: redefinition of 'int ADC_Value'
 int ADC_Value = 0;
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:21:5: note: 'int ADC_Value' previously defined here
 int ADC_Value = 0;
sketch_dec13a:380:7: error: redefinition of 'float Vcc'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:22:7: note: 'float Vcc' previously defined here
sketch_dec13a:381:7: error: redefinition of 'float BAT_Voltage'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:23:7: note: 'float BAT_Voltage' previously defined here
sketch_dec13a:382:7: error: redefinition of 'float sample'
 float sample =0;
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:24:7: note: 'float sample' previously defined here
 float sample =0;
sketch_dec13a:383:6: error: redefinition of 'byte Hour'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:25:6: note: 'byte Hour' previously defined here
sketch_dec13a:383:16: error: redefinition of 'byte Minute'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:25:16: note: 'byte Minute' previously defined here
sketch_dec13a:383:28: error: redefinition of 'byte Second'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:25:28: note: 'byte Second' previously defined here
sketch_dec13a:384:6: error: redefinition of 'bool calc'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:26:6: note: 'bool calc' previously defined here
sketch_dec13a:384:20: error: redefinition of 'bool Done'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:26:20: note: 'bool Done' previously defined here
sketch_dec13a:385:17: error: redefinition of 'Button UP_Button'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:27:8: note: 'Button UP_Button' previously declared here
sketch_dec13a:386:19: error: redefinition of 'Button Down_Button'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:28:8: note: 'Button Down_Button' previously declared here
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino: In function 'void setup()':
sketch_dec13a:389:6: error: redefinition of 'void setup()'
 void setup () {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:31:6: note: 'void setup()' previously defined here
 void setup () {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino: In function 'void loop()':
sketch_dec13a:417:6: error: redefinition of 'void loop()'
 void loop() {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:59:6: note: 'void loop()' previously defined here
 void loop() {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino: In function 'void timerInterrupt()':
sketch_dec13a:461:6: error: redefinition of 'void timerInterrupt()'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:103:6: note: 'void timerInterrupt()' previously defined here
sketch_dec13a:536:7: error: redefinition of 'void setup()'
  void setup() {
 void setup () {
sketch_dec13a:541:6: error: redefinition of 'void loop()'
 void loop() {
 void loop() {
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Offline DrG
Re: compiler issues
« Reply #1 on: December 13, 2020, 03:23:48 pm »
Look in the folder where the program is stored. My guess is that you have two .ini files there.
Edit: I just noticed that you posted this in different threads....and someone else also suggested that you have multiple .ini files in the folder.
« Last Edit: December 13, 2020, 03:33:06 pm by DrG »
- Invest in science - it pays big dividends. -
Offline ozcar
Re: compiler issues
« Reply #2 on: December 13, 2020, 11:15:39 pm »
Maybe you mean two .ino files?
I have not seen this in any other thread though - maybe that/those did say .ino rather than .ini.
Offline DrG
Re: compiler issues
« Reply #3 on: December 14, 2020, 12:14:23 am »
No, I made a typo and meant .ino file. Did you solve it yet? Did you look in the folder?
Offline ozcar
Re: compiler issues
« Reply #4 on: December 14, 2020, 12:50:44 am »
It wasn't me with the problem.
You're probably on the right track though. Stray files with other extensions, like .pde, .c or .cpp could cause trouble too.
Re: compiler issues
« Reply #5 on: December 16, 2020, 08:41:46 pm »
sorted,the file was repeated,deleted one and bingo,cheers all.
