Author Topic: Converting BCD(mm) to BCD(inch)[SOLVED]  (Read 4599 times)
Online jpanhaltTopic starter
Re: Converting BCD(mm) to BCD(inch)
« Reply #25 on: November 27, 2023, 12:24:15 pm »
There are two main purposes to this project: 1) Allow control of threading feed (i.e., an auto stop); and 2) Repurpose Mitutoyo scales currently on my mill to use on my lathe.  For my mill, I will be going with a more modern DRO that has all sorts of built-in functions but uses inexpensive glass scales.
The Mitutoyo scales are inductive, more compact than glass, and quite robust with respect to contamination.  They will be happy on the lathe, and because they are smaller and more robust, I may be able to fit one to the cross feed.  That will not be easy even with the Mitutoyo scales.
I agree multiplication is probably faster and just haven't played with it yet.
Online Doctorandus_P
« Reply #26 on: November 27, 2023, 12:30:46 pm »
I once had to do a bit of assembly for a z80 as part of a high school course. It was quite fun as a learning experience. we had to program a calculator. I did try to use packed BCD as the Z80 does have instructions for a half carry and BCD adjustment but that was not feasible. I put in a lot more effort then my classmates and used at least three different simulators which all had different bugs in handling the flags for these instructions.
The school software was also atrocious. It had a nice looking GUI, but could do a few hundred of instructions per second. I used a cross assembler and emulator with debug monitor and when I had to demonstrate my calulator at school my arbitrary length rpn calculator took 5 minutes or so to do a simple calculation :)
But if you do BCD, then you can also use a simple 100byte LUT for multiplication. Shift one BCD number four bits, add the other bcd number, and do an array lookup to get a two digit packed bcd result.
but overall, if you want improvement of the 1000 cyle total, start with looking at individual parts of the algorithm. Maybe there are optimized libraries for PIC15 for (packed?) BCD...
« Reply #27 on: November 27, 2023, 12:45:57 pm »
For threading, you  have to map one scale to another, do it quickly but only in small increments. A well known youtuber (cloud 42 something) has open sourced a project for this, but he uses a TMS320, which I regard as total overkill for a project like that.
If you want to do it lean an mean, then input from a quadrature / grey encoder is best. You can put it's output into a modified bresenham line algorithm to get a very high resolution. Forget about mm and banana units. Just work in whatever units map directly to your hardware.
And this likely exposes another problem. Those mitutoyo things probably use some (low to moderate baudrate) serial output, and the update rate will be low. Very likely much slower then your own algorithm. So with what frequency can you read your scales?
The Bresenham line algorithm does not work well for slow inputs with big gaps. For Bresenham you want small incremental inputs, and you want the input to have a higher update rate then the output.
If you do want further optimization, maybe it is feasible to only work with differences and increments. Maybe you can work with two (or three) digits, instead of calculating the full number each time.
« Last Edit: November 27, 2023, 12:52:56 pm by Doctorandus_P »
« Reply #28 on: November 27, 2023, 02:04:47 pm »
I am quite familiar with Clough42's videos on an electronic lead screw.  Notice, that he still uses half-nuts to disengage threading.  That gets complicated if one is doing metric threads with an imperial lead screw.   But that is not the problem I am trying to solve.  I can no longer trust my reflexes, concentration, and coordination to stop before crashing when cutting RH threads -- particularly internal threads where visibility is poor.
Years ago (2009), I made an electronic stop based on detecting the "negative" bit from a Mitutoyo scale (the same series of devices I am playing with today).  The MCU was a 12F509 that I was learning on.  That worked on my miniature Prazi lathe that lacked half-nuts.  The current project is for a bigger lathe, and of course, I will add other enhancements.  An ELS, while related , is not the same.  Clough42's project avoids gear changing.  I do not find that to be a burden.  My lathe has a quick-change gear box, plenty of imperial options, and if need be, even limited metric threads.
Online newbrain
« Reply #29 on: November 27, 2023, 02:07:53 pm »
Small correction: 154 byte LUT. (99 HEX == 153 DEC).
« Reply #30 on: November 27, 2023, 04:32:33 pm »
A two dimensional 10x10 byte LUT?  :popcorn:
I have made custom threads on my lathe only a few times, so I am quite inexperienced with that part.
A long time ago I did mount a frequency inverter on the main motor, and this was a great help to overcome my anxiety. I just use the mechanical gears for a coarse rpm selection (increased torque at low RPM) and for the rest, I just dial the rpm down with a potentiometer.
I also have an RongFu 30 (the ubiquitous mill/drill with the round column) and have some contactors to switch the inverter between the lathe and the mill. I have also set up the inverter to have a low torque at low rpm. I can now tap M5 holes and just let the tap bottom out in a blind hole, then flip a small switch and dial up the potentiometer for a rapid reverse. I have no need for a "real" tapping head at all.
Offline Nominal Animal
« Reply #31 on: November 27, 2023, 04:48:19 pm »
Yup, index = m1 + (m2 << 1) + (m2 << 3).  It's difficult to say whether that is faster or slower than combining nibbles from two different bytes. And most of those entries will be unused in this case.
« Reply #32 on: November 27, 2023, 05:01:54 pm »
For two dimensional I'm more thinking along:
Quote from: Me
output = lut [ m1 ] [ m2 ];
and let the C compiler manage the details. I have not written any assembly in the last 20 years.
« Last Edit: November 27, 2023, 05:58:00 pm by Doctorandus_P »
« Reply #33 on: November 27, 2023, 06:35:31 pm »
output = lut[m1][m2];
That's the equivalent in C for unsigned char lut[10][10], yes.
« Reply #34 on: November 27, 2023, 08:14:06 pm »
If we have two integer numbers mm and in,
    mm = 100 * millimeters
    in = 2000 * inches
then the conversions between the two are
    mm_to_inch(mm) = (mm * 100 ± 63) / 127
    inch_to_mm(in) = (in * 127 ± 50) / 100
where ± means addition if mm or in is positive, subtraction if negative.
For display purposes, you do need to multiply in by five.
Unfortunately, inch_to_mm(mm_to_inch(mm)) == mm±1: the roundtrip is off by 0.01mm in about 21% of cases, because the mm_to_inch() conversion maps a wider range to a narrower range: more than one reading in tens of micrometers maps to the same reading in half-thousandths of an inch.  This cannot be avoided, unless the inches precision is increased; and that means the final digit can be something other than 0 or 5.
If the final digit can be any even digit, i.e.
    in = 5000 * inches
and you double in for display purposes, then
    mm_to_inch(mm) = (mm * 250 ± 63) / 127
    inch_to_mm(in) = (in * 127 ± 125) / 250
and you get a 1:1 mapping between inches and millimeters.
Since 250 / 127 = 1000 / 508 = 1/0.508, you could implement
    mm_to_inch(mm) = 2*round( mm / 0.508 )
which includes the doubling for display purposes, i.e. the result is in ten-thousandths of an inch; or equivalently
    mm_to_inch(mm) = round_to_even( mm / 0.254 );
i.e.
    int mm_to_inch(const int mm) { return 2*round((double)mm * 250.0 / 127.0); }
or, equivalently,
    int mm_to_inch(const int mm) { return 2*(int)(mm * 250 + (mm < 0 ? -63 : +63)) / 127);
or, equivalently,
    unsigned int  u = (mm < 0) ? -mm : mm;
    int           n = 0;
    // Up to 15 iterations
    while (u >= 65024) {
        u -= 65024; // 0b1111'1110'0000'0000 = 127 << 9
        n += 256;
    while (u >= 4064) {
        u -= 4064;  // 0b1111'1110'0000 = 127 << 5
        n += 16;
    while (u >= 254) {
        u -= 254;   // 0b1111'1110 = 127 << 1
        n++;
    // We now have (n = abs(mm) / 254, u = abs(mm) % 254
    n *= 1000;  // n = (n << 10) - (n << 3) - (n << 4);
    u *= 1000;  // u = (u << 10) - (u << 3) - (u << 4);
    // Up to 31 iterations
    while (u >= 8128) {
        u -= 8128;  // 0b0001'1111'1100'0000 = 127 << 6
        n += 32;
    while (u >= 254) {
        n++;
    // Round to even
    n += (n & 1);
    return (mm < 0) ? -n : n;
The three mm_to_inch() functions above do produce identical results for -999999 ≤ mm ≤ +999999; I checked.
And, as I mentioned above, this is bijective: each unique mm value maps to an unique even in value, which if multiplied by 0.254 and rounded, will yield the original mm value.  For half-thousandths of an inch, bijective mapping is not possible.
« Last Edit: November 27, 2023, 08:18:35 pm by Nominal Animal »
Offline SiliconWizard
« Reply #35 on: November 27, 2023, 09:51:32 pm »
You don't need to store the 0's - unless the cost of a comparison and branch is much more than accessing memory, but that's very probably not the case on a PIC16F. A small detail that can be checked depending on the target.
So you only need a 9x9 LUT, not 10x10.
« Reply #36 on: November 27, 2023, 10:20:41 pm »
You could optimize further, If the most significant digit is a zero, then input and output is the same and you could check for that too. But it is all adding software complexity for saving a few bytes of RAM.
Also, with just a complete LUT, there are no extra comparisons at all, so it will be (some insignificant amount) faster.
But to me it all looks like abuse of brain power. I rather spend that brain power on learning how to use 32bit uC's in a reasonable efficient way. Those things go up to several hundredths of MHz and Megabytes of Flash, RAM, DMA, multiple ISR levels and a gazillion other fun peripherals to toy with.
Offline thm_w
  • Non-expert
« Reply #37 on: November 28, 2023, 01:07:13 am »
Yeah, ~$2 will buy you a much more capable MCU so you don't have to dick around with a bunch of optimization and can add more features later if needed.
Online westfw
« Reply #38 on: November 28, 2023, 02:30:05 am »
Just out of curiosity, has anyone ever seen a microcontroller with some sort of assist for BCD multiply or divide?
Offline IanB
« Reply #39 on: November 28, 2023, 03:16:08 am »
This is related to some recent threads of mine about reading Mitutoyo linear scales.  The bare sensors (e.g., the ones on my mill) report six, 4-bit BCD bytes in mm.  I need to convert to inches for display.  By brute force, I have converted to binary, divided by 25.4 (fixed point), and converted back (22 bit) to BCD.  That requires about 1,000 instruction cycles or a little less.  The 22-bit conversion works because the scales are less than 1 meter long.
I have been reading about doing that math in BCD, which I understand was common years ago and may still be used in the financial industry and some small calculators.  My chosen MCU is a PIC16F1xxx, and it has no "BCD-friendly" instructions like the PIC18F MCU's have (e.g., DAW, decimal adjust W). I also work in Microchip Assembly exclusively (MPASM).
Has anyone here done BCD multiplication and/or division on an 8-bit controller without BCD instructions?  Would you recommend going that direction or sticking with the brute force method?
Regards, John
Personally, I think I would be inclined towards a much simpler brute force approach than this, and just do straightforward decimal division the old fashioned way, as it used to be done on mechanical desk calculators by turning the wheel: repeated subtract and shift.
Basically you enter the dividend into the notional accumulator as a string of decimal digits and keep subtracting the divisor until you can go no further. Each subtraction adds 1 to the output (quotient) register. Then shift right one decimal place and repeat. Do this over and over until you have the required precision. Doing this by hand on the desk calculator only took a few seconds, with about three subtractions per second (depends how fast you can turn the handle).
On a microprocessor, I suspect this is just a couple of nested loops and a few dozen (OK, several dozen) instructions.
You surely will not do high performance computing this way, but do you need anything more for this application?
Illustration below:
Input is 15.712 mm
Initialize with 0 in the output register:
                   : 0
Try to subtract:
  15712
- 25400   X
Fails, so shift right one decimal:
-  2540   = 13172  : 01
-  2540   = 10632  : 02
-  2540   = 8092   : 03
-  2540   = 5552   : 04
-  2540   = 3012   : 05
-  2540   =  472   : 06
-  2540   X
Fails with 6 as the first decimal place.
Shift right again, and continue, shifting each time the subtraction fails:
-   254   =  218   : 061
-   254   X
2180
-   254   =  1926  : 0611
-   254   =  1672  : 0612
-   254   =  1418  : 0613
-   254   =  1164  : 0614
-   254   =   910  : 0615
-   254   =   656  : 0616
-   254   =   402  : 0617
-   254   =   148  : 0618
-   254   X
1480
-   254   =  1226  : 06181
-   254   =   972  : 06182
-   254   =   718  : 06183
-   254   =   464  : 06184
-   254   =   210  : 06185
-   254   X
Enough precision needed, so stop.
210 > 127 so round up. Result is 0.6186 inches.
« Last Edit: November 28, 2023, 03:19:34 am by IanB »
« Reply #40 on: November 28, 2023, 10:15:49 am »
Subtract and rotate is basic to some cordic procedures and procedures labeled "novel" methods on PICList (http://techref.massmind.org/techref/method/math/muldiv.htm).  The "Kenyan" method* is near the bottom of the page.  I played with it over a couple of Winters a few years ago.  Attached is rough code for a 16x16 division.*  It is fast.  I have code for different sizes and have used it routinely. The enhanced midrange chips have two new instructions, subwfb and addwfc,  that make multi-precision math quicker as they automate dealing with the carry/borrow bit.
Dividing by a constant is particularly easy as you know how much it needs to be rotated to be greater than (dividend/2) +1 that the algorithm requires.  I did some trial runs rotating the metric result (max = 5 bytes), e.g., xxx.xx) so that I get a nice 6-byte (dd.dddd) result and a remainder that can be ignored.  Five byte + remainder for rounding is another option.  Right now, I need to decide whether multiplying or dividing is better.  My suspicion is that dividing will prevail as the divisor has fewer non-zero bits than the multiplier.  That is easy to test.  The other thing that will be assessed is whether testing the dividend  for number of bits will save time.  Five unpacked BCD bytes is 17-bits; four BCD bytes is only 14 bits.  That saves a few rotations, but the cost might not be worth the effort overall.
Right now, I am dealing with a lot of totally unrelated issues and have very little time for this project.  I do appreciate all of the advice and have saved the code suggestions to review.  My initial question of whether to pursue BCD math or go the BCD > BIN > math >BCD route has been answered.
Thank you all.
Regards, John
*Notice there is no correction for an unsuccessful subtraction.  The negative result is simply dealt with in the next step.  The same name has been applied to a similar multiplication algorithm.  The "bit banging" part can be omitted.
« Last Edit: November 28, 2023, 10:19:38 am by jpanhalt »
« Reply #41 on: November 28, 2023, 02:56:00 pm »
As mentioned earlier, I have posted the current version of my 20-bit BIN2BCD code here:
https://www.eevblog.com/forum/microcontrollers/20-bit-bin2bcd-(assembly)/new/#new
Link and explanation of 16-bit BIN2BCD by Payson w/ explanation by Dattalo:
https://pic.hallikainen.org/techref/microchip/math/radix/b2bu-16b5d.htm
Link to 17-bit BIN2BCD:
https://pic.hallikainen.org/techref/microchip/math/radix/b2bu-17b5d.htm
I have also attached the code here for those who hate to click on links and hope that doesn't violate any rule.  I would appreciate comments for improvement.  This is not fresh code.  It is basically the 17-bit code I wrote earlier with a bandaid addition to expand it.
John
Offline AVI-crak
  • Country: ru
    • Rtos
« Reply #42 on: November 28, 2023, 09:23:48 pm »
Metric systems are not needed for feed rate control and mark setting. Millimeters and inches are an option for displaying information, and are not suitable for controlling iron.
What you really need is a fractional binary number (an unsigned fixed-point integer). By the way, rounding in such calculations is always obtained naturally - approximation to zero. The error does not accumulate!!!
« Reply #43 on: November 28, 2023, 11:10:08 pm »
I don't understand.  In a general sense, maybe, but in the specific case of the Mitutoyo linear sensors, is there an option?  How would you do it?  The output is BCD metric.
Offline IanB
« Reply #44 on: November 28, 2023, 11:58:18 pm »
If we were talking about an industrial CNC machine, then the internal controls and position sensors might work in binary. But this isn't your use case, and so it does not apply.
« Reply #45 on: November 29, 2023, 12:15:09 am »
That is precisely not necessarily the case, which is why I mentioned it clearly in my post. Depends entirely on the target and context. Indexed memory access in the PIC16F, as I recall, was pretty slow, and IIRC (may not quite), they would actually consist in using a branch. But that's old memories. Besides, a dual-entry array? Even worse.
In any case, the idea that indexed memory access may be faster than a test and branch is entirely dependent on the target (and context again, such as cache), and turns out very often false - that was almost invariably true on older CISC architectures with no caches, but very often not true in other cases. Whether on small MCUs or fast desktop/server CPUs, the actual result will usually surprise you.
« Reply #46 on: November 29, 2023, 01:06:01 am »
The PIC16F1xxx has the entire RAM memory linearly mapped.  Access is by the FSRx registers.  You can also use program memory with FSRx.I wouldn't consider that slow even compared to a few lines of code.  When I get time, I have an idea for a table based system.  Probably won't work, but worth a try.
« Reply #47 on: November 29, 2023, 08:26:39 am »
Really. I have never used the 16F1xxx, but the original 16Fxxx series, with its banks and it was pretty tough to deal with. I suppose they have improved the 16F series significantly then.
« Reply #48 on: November 29, 2023, 09:00:01 am »
Attached is the mapping for one member of that series.  Notice the high byte of the addresses in the far right columns is 0x20.   That's the key.  Just set FSRxH to 2, and it will know to address that Ram as linear.  Common Ram is protected (bytes usually beginning at 0x70) is protected and still usable.  One can also continue to use banked GPRam by carefully picking which segment of linear memory to use.  For example, my constants for routines used to  manipulate an SPI GLCD are in Bank 4 to avoid  frequent bank switching and gain speed.  Thus, linear memory used to refresh the screen begins and ends before Bank 4.
« Last Edit: November 29, 2023, 09:03:04 am by jpanhalt »
« Reply #49 on: November 29, 2023, 03:29:27 pm »
I tried a table approach for the conversion, and it looks promising.  It's not quite BCD math, but there is no code to convert the BCD sensor result to binary.  So, in the spirit of the times, I will call it a hybrid.
All I did was make an Excel table with 5 columns which corresponded from right to left of the digits in the metric reading.  That is, 0.01x, 0.1x, 1x, 10x, and 100x, respectively.  Excel then calculated each multiplier x each digit divided by 25.4 and multiplied by 10^5 for fixed point.  The decimals values in Excel were fine, but in a mirrored table converted to hex, I found 2 errors/differences in the Excel table versus what assembler and my handheld calculator.  Specifically, for d.197 the assembler gave 0xC5 and Excel gave 0xC4.  For d.1968504, Excel gave 0x1E0977 and the assembler gave 0x1E0978.  I converted the Excel table to values before doing the hex conversion.
The MCU was an enhanced midrange in simulation.  That has addwfc and subwfb instructions for multiprecision math and brw for making table reads simpler.  At this point, the code is rough, linear, and lengthy.  I will be using indirect addressing or a macro to avoid all the clutter from repeated sequences for each byte.
Conversion of 567.95 mm to 22.3602" in binary took 144 Tcy.  If BIN2BCD is 300 Tcy, then total will be 111 us at 16 MHz.
Attached is a snippet of the code and the full table should anyone else want to play with it.
