Author Topic: DAC - Sam D21 Bare Code Driver  (Read 9363 times)
Offline FrancTopic starter
  • Country: br
« on: October 09, 2016, 09:31:32 pm »
Hi friends!
I am starting to use the DAC of Sam D21 .
I would like to code it in Bare Metal.
Anyone has an example driver configuration to me study together DS? I have some doubts to coding it.
Best Regards
Online ataradov
    • Personal site
Re: DAC - Sam D21 Bare Code Driver
« Reply #1 on: October 09, 2016, 10:33:28 pm »
What you've got so far and what does not work?
Alex
Online rstofer
Online ataradov
    • Personal site
« Reply #3 on: October 09, 2016, 11:59:10 pm »
Why not start with the App Note?
The question is about bare-metal implementation and this AN can't be any further away from that.
Alex
  • Country: br
« Reply #4 on: October 10, 2016, 12:31:17 am »
Hi RSTOFER, yes I checked that file but all information is in ASF. I do not like ASF  :-\.
I searched a lot the driver configuration in Bare Code like that ASF file shows but no success for Bare Code.
Dear Alex, I cannot understand how I can do the syncronization for write data to DATA.reg.
Regards
Online ataradov
    • Personal site
« Reply #5 on: October 10, 2016, 12:38:42 am »
Don't think about synchronization. It is not going to affect you in this case.
Alex
  • Country: br
« Reply #6 on: October 10, 2016, 12:48:39 am »
Alex, in page 934 of DS means:
'The following bits need synchronization when written:
• Software Reset bit in the Control A register (CTRLA.SWRST)
• Enable bit in the Control A register (CTRLA.ENABLE)
• All bits in the Data register (DATA)
• All bits in the Data Buffer register (DATABUF)
so, the STATUS.SYNCBUSY is not relevant?
Thanks friend!!!
Online ataradov
    • Personal site
« Reply #7 on: October 10, 2016, 12:53:22 am »
Synchronization is needed if you are worried about interrupt latency (within a few clock cycles). If you do two writes in a row into the registers that need synchronization, then the second write will block the system bus until the first one completes. If you only write DATA register once in a while, then you have noting to worry about.
At the same time, it is not that hard to do the synchronization. Just do something like
  while (DAC->STATUS.reg & DAC_STATUS_SYNCBUSY);
before the write to the DATA register.
Alex
The following users thanked this post: Franc
  • Country: br
« Reply #8 on: October 10, 2016, 11:44:38 pm »
When I debug my code with the dac_carga_init() in main.C, my program blocks.
I have configured my DAC drive as below. I dont know what happens dear Alex.
#include "samd21.h"
#include "board_defs.h"
void dac_carga_init(void)
PM->APBCMASK.reg |= PM_APBCMASK_DAC; // Enable peripheral clock for DAC
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID (DAC_GCLK_ID) | // DAC share same GCLK
GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN (DAC_GCLK_SOURCE);
while (GCLK->CLKCTRL.reg & GCLK_CLKCTRL_CLKEN); // Wait till enabled
GPIO_dirOut(DAC_OUT); //PA02
GPIO_pmuxen(DAC_OUT, DAC_OUT_PMUX); //PMUX B for PA02 pin DAC
DAC->CTRLA.reg &= ~(DAC_CTRLA_ENABLE); //Disable DAC to permit change CTRLA B register.
DAC->CTRLB.reg |= DAC_CTRLB_EOEN | DAC_CTRLB_REFSEL_AVCC; //Enable the DAC output on Vout pin. Enable VDDANAL REF.
DAC->CTRLA.reg |= DAC_CTRLA_ENABLE; //Enable DAC
.h file:
#ifndef DAC_CARGA_H_
#define DAC_CARGA_H_
void dac_carga_init(void);
inline uint16_t dac_carga_write(uint16_t carga);
// uint16_t received_data;
while (DAC->STATUS.reg & DAC_STATUS_SYNCBUSY); // Make sure clock synchronization
DAC->DATA.reg = (carga); // Write DAC value
#endif
Best Regards friends!
Online ataradov
    • Personal site
« Reply #9 on: October 11, 2016, 12:01:23 am »
Here is a full source code that works. If you want to test this as is, you can replace main.c here https://github.com/ataradov/mcu-starter-projects/tree/master/samd21 with this code.
You can go fancy with synchronization and stuff, but as I said, it is not necessary in most cases.
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include "samd21.h"
#include "hal_gpio.h"
HAL_GPIO_PIN(DAC,      A, 2)
static void sys_init(void)
  // Switch to 8MHz clock (disable prescaler)
  SYSCTRL->OSC8M.bit.PRESC = 0;
static void dac_init(void)
  HAL_GPIO_DAC_out();
  HAL_GPIO_DAC_pmuxen(PORT_PMUX_PMUXE_B_Val);
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID(DAC_GCLK_ID) |
    GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN(0);
  DAC->CTRLA.reg = DAC_CTRLA_SWRST;
  while (DAC->CTRLA.reg & DAC_CTRLA_SWRST);
  DAC->CTRLB.reg = DAC_CTRLB_EOEN | DAC_CTRLB_REFSEL_AVCC;
  DAC->CTRLA.reg = DAC_CTRLA_ENABLE;
static void dac_write(uint16_t value)
  DAC->DATA.reg = value;
int main(void)
  int dac_out = 0;
  sys_init();
  dac_init();
  while (1)
    dac_write(dac_out++);
  return 0;
Alex
  • Country: br
« Reply #10 on: October 11, 2016, 12:21:03 am »
In page 33 of DS SAMD21 says that PA02 is the only pin for Vout of DAC. Is possible I use any other Analog pin for do it once all are MUX B?
(PA02 til PA07 and PB00 till PB09)
Thanks!
Online ataradov
    • Personal site
« Reply #11 on: October 11, 2016, 12:22:11 am »
I don't understand the question.
Alex
  • Country: br
« Reply #12 on: October 11, 2016, 12:28:25 am »
Sorry,... Could I use  any other Analog Pin to DAC Vout? In DS, page 33, shows only PA02 as Vout, but I am using the PA02 with my OLED Xplained Pro in EXT03.
Online ataradov
    • Personal site
« Reply #13 on: October 11, 2016, 12:30:23 am »
No, the table "Table 6-1. PORT Function Multiplexing" lists all possible multiplexing options. If it is not in the table, it is impossible. In case of DAC, only PA2 is possible.
Alex
  • Country: br
« Reply #14 on: October 11, 2016, 10:37:25 pm »
Still blocking my program when I call the dac_carga_init().
I am using the SERCOM5 SPI in same EXT03.
Also in my program I am using the TCC0 TC4 TC5, SERCOM0 SPI in EXT1.
My GCLK(0) is DFLL 48Mhz. Do you know if there is any incompatibility to use them together DAC?
Below my dac_carga_init():
GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN (0);
DAC->CTRLB.reg = DAC_CTRLB_EOEN | DAC_CTRLB_REFSEL_AVCC; //Enable the DAC output on Vout pin. Enable VDDANAL REF.
DAC->CTRLA.reg = DAC_CTRLA_ENABLE; //Enable DAC
while (DAC->STATUS.reg & DAC_STATUS_SYNCBUSY);//Wait until clock ok.
Best Regards
Online ataradov
    • Personal site
« Reply #15 on: October 11, 2016, 10:42:46 pm »
I'm pretty sure this is wrong. And the whole line is unnecessary.
Alex
  • Country: br
« Reply #16 on: October 11, 2016, 11:02:31 pm »
 :palm: :phew: ..You are the guy..Alex! Worked perfect. Thanks.
By the way.... why this line is wrong? ' while (GCLK->CLKCTRL.reg & GCLK_CLKCTRL_CLKEN); // Wait till enabled'
I have used it to all my TC and no issues.
Regards!
Online ataradov
    • Personal site
« Reply #17 on: October 11, 2016, 11:04:51 pm »
If you really want to wait until the clock is enabled, then it should be "while (0==(GCLK->CLKCTRL.reg & GCLK_CLKCTRL_CLKEN));". Your TC is probably clocked from a slower clock, so it takes a few cycles for it to enable, so it was falling though on the first iteration.
In general, it probably is a good practice to wait, but in reality, even if clock is not enabled, your first access to the peripheral register will block until clock is enabled.
« Last Edit: October 11, 2016, 11:06:44 pm by ataradov »
Alex
  • Country: br
« Reply #18 on: October 11, 2016, 11:15:24 pm »
OK, nice clue!
*Now I will start in Analog Comparators of Sam D21.
Best Regards!  :-+
