Author Topic: DE0 board getting started  (Read 1736 times)
Offline mnTopic starter
« on: May 04, 2017, 02:30:28 pm »
We have a DE0 (www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&No=364) board and the manual is quite straight forward. Consider this simple counter code
library ieee;
use ieee.std_logic_1164.all;
entity counter2 is
port( clk, rst: in std_logic;
  q: out integer range 0 to 31);
end;
architecture x of counter2 is
begin
process( clk, rst )
variable tmp: integer := 0;
begin
if ( rst = '1' ) then
tmp := 0;
elsif (clk'event and clk = '1') then
tmp := tmp + 1;
if ( tmp = 32 ) then
tmp := 0;
end if;
end if;
q <= tmp;
end process;
end;
According to the manual (http://www.terasic.com.tw/cgi-bin/page/archive_download.pl?Language=English&No=364&FID=0c266381d75ef92a8291c5bbdd5b07eb), the push button pins are described in page 27 fig 4-5
F1 -> CLK
G3 -> RST
And the LEDs are described in page 28, fig 4-8 (J1, J2, J3, H1, F2). I configured the chip with these pins. As you can see in the attached picture, the programming phase is done successfully and I see that board initial works (flashing leds) are stopped for programming. However, as I press the buttons, the LEDs don't work. If you look at the attached board picture, the five bits (output q) are turned off which shows the board is configured.
Any idea to debug more?
Re: DE0 board getting started
« Reply #1 on: May 04, 2017, 02:58:23 pm »
Excuse me. I made a mistake. The buttons high positions are (1) so the circuit was always in the reset mode. Please remove this topic.
