Hello.
I'm trying to debug code on STM32F030.
SWD debug wire is enabled. All updates are done, etc...
I can get into debug mode!
The problem is that the code blocks whenever a HAL_Delay() occurs.
I think the problem is related to systick timer, because the program counter does not move from there.
I do not know how to solve this problem. I already tried several things, but I did not find anything concrete about someone who had this problem.
I'm using SW4STM32, ST-Link utility and ST-link V2.
Look at this picture (ignore the 'expressions' tab)
The code is very simple, as you can see here.
PS: I've never had an answer with solutions in the ST forums (several past experiences). So I'm putting this post here because it seems to be much more frequented and capable than the ST forum itself.
