Author Topic: LED stops flashing after removing programmer  (Read 11497 times)
Offline Kremmen
Re: LED stops flashing after removing programmer
« Reply #25 on: December 05, 2012, 07:15:28 pm »
Yup, uses debugWire as one of the optional protocols. That in turn communicates over the reset pin so you do not want to leave the debugger/programmer pulling reset down when powered off.
debugWire is used for debugging and ISP for flash programming; both connections are made using the 6 pin header so you would want to disconnect the prog cable when starting normally with the programmer off.
Nothing sings like a kilovolt.
Dr W. Bishop
