Author Topic: Debugging embedded systems  (Read 1877 times)
Offline wrynczukTopic starter
« on: April 12, 2017, 05:16:10 pm »
Some time ago I created a free and open application which facilitates debugging embedded systems. It just allows for an easy visualization of text log files. It might be used to debug small and large systems. Since its first release the application has grown a little. Currently, there are Windows and Linux distributions available. It also allows for merging logs from different sources.
I strongly encourage you to give it a try.
Just visit vcdmaker.org. You will find there the application itself, the manual as well as short videos demonstrating what it is.
Enjoy it  ;D
« Last Edit: April 12, 2017, 05:21:11 pm by wrynczuk »
Offline whalphen
Re: Debugging embedded systems
« Reply #1 on: April 12, 2017, 09:30:47 pm »
Thank you.  I will try this.  I work with local school electronics clubs.  We will launch high altitude balloons and log a lot of data from several sensors.  This will help us to analyze the data.
« Reply #2 on: April 13, 2017, 07:17:01 am »
What a great idea! If you use your own logging format than you will have to transform the log to the format expected by vcdMaker. As this is a linear transformation (line to line) it shall not be difficult (e.g. using Python). I can offer my assistance if needed. We are working on removing this limitation so as vcdMaker could parse any format of the user log.
Anyway I would be very interested in seeing the results you get. Good luck on flying the balloons! Let the force be with you  :-+
