Author Topic: Decoding ESP-NOW Radio Transmission intercepted by HackRF  (Read 3369 times)
Offline bb1Topic starter
« on: September 11, 2022, 02:48:07 pm »
ESP-NOW uses one of the oldest Wi-Fi modulation versions,
Direct-Sequence Spread Spectrum (DSSS) with bitrate of 1Msps.
While this version seems to be outdated, for compatibility with old devices
this modulation is used in Access Point Beacons.
For ESP-NOW the DSSS has advantage that it permits higher transmitter power and is
less sensitive to interference and noise, so it can work at longer distances.
It is interesting to see the structure of ESP-NOW transmitted signal
without using very expensive real-time spectrum analyzer.
Digitized 8-bit IQ version of such signal can be intercepted by HackRF and saved to a file
using hackrf_transfer.exe.
For simplicity only one at a time Wi-fi packet data from such file is treated by the
attached decoding Python program
decodeWifi_1Mbps_packet.py.
Part of the plot of IQ data for such captured packet is shown on the attached
zoomed_transmitter_IQ.png.
It looks complicated, with I and Q components changing in all possible ways.
However, it is known that the transmitted signal uses DBPSK modulation,
which permits to rotate the data phase to remove Imaginary component.
Costas Loop transform, code for which is mostly borrowed from pysdr.org,
does the phase rotation in the Python program.
Portion of the result is shown at zoomed_Costas_loop_output.png.
The imaginary component is significantly reduced, so that it can be discarded.
At transmitter, the signal bits were multiplied by Barker sequence
which has length of 11 chips per one bit (or one microsecond).
To recover transmitter bits before the Barker sequence was applied,
it is necessary to correlate Barker code with Costas loop output
which has 20 samples per microsecond.
To make correlation possible, Barker code should be upsampled using factor of 20,
while Costas loop output upsample factor should be 11.
Upsampling and correlation are performed in the python program.
Correlation result, part of which is shown on figure zoomedCorrelation.png,
looks very impressive.
The correlation has strong narrow peaks at positions of the bits.
Up peaks can be assigned bits equal to one, then down peaks correspond to zero bits.
Python file extracts bit array from the peaks.
After that differential encoding of the bits is reversed.
The result is given to Descrambler to get final bits.
At the start of final bits array there is preamble of 128 ones.
It may be slightly spoiled at the very beginning,
so the real start of data bytes is where the ones end,
and two bytes of known Start Frame Delimiter (SFD) begin.
SFD position can be found by correlating first 160 final bits with SFD.
Part of the final bits array containing SFD is shown on zoomed_descrambledBits_andSFD.png
After the accurate start of non-trivial data is found,
the final bit array is transformed to bytes.
The Python program prints the resulting array of bytes,
as well as some values found in this array,
such as transmitter and receiver Mac addresses, frame type, and available user data.
Payload array is part of bytes array starting at address 8.
The Payload can be saved to pcap file and examined in minute details by WireShark.
Necessary minor additions to make proper pcap file can be found on the Web.
The ESP_NOW sends data using Vendor Specific Action Wi-Fi frame.
Format of the Payload for this frame is described at
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/network/esp_now.html
The actual unencrypted ESP_NOW user data
start at the address 39 of Payload array and
end before last 4 bytes of the Payload.
As can be seen from the text of the Python program,
it was tested for one intercepted Access Point beacon,
and two intercepted ESP_NOW frames.
The first ESP_NOW frame was sent by transmitter to receiver,
and the second ESP_NOW frame was just ACK sent by receiver as reply for the first frame.
IQ data intercepted by HackRF for both frames are shown at sentDataAndACK_hackRF_IQ.png.
Useful data for this ESP_NOW transfer consisted of array of only 4 bytes "a","b","c",'d".
At the 1Mbps rate the transmission of 4 bytes should take only 32 microseconds.
In reality, as can be seen from sentDataAndACK_hackRF_IQ.png,
the first frame took about 600 uS, and the ACK took about 300 uS,
so this minimal ESP_NOW transfer took almost one millisecond.
Python program output for the decoded transmitter frame intercepted by the HackRF is shown here:
len(data)= 23160
Length of byteArr= 55
[160 243  10   4 120   1 156 108 208   0  58   1  48 174 164 244  22  60
 120  33 132 128  65  16 255 255 255 255 255 255 208 236 127  24 254  52
  57  19 236 115 221   9  24 254  52   4   1  97  98  99 100 118  44 208
 112]
Length of data Payload= 376 uS
Number of Payload bytes= 47.0
destMac= ['0x30' '0xae' '0xa4' '0xf4' '0x16' '0x3c']
sourcMac= ['0x78' '0x21' '0x84' '0x80' '0x41' '0x10']
Action frame
userData= [ 97  98  99 100]
userData characters= ['a', 'b', 'c', 'd']
The following users thanked this post: czorgormez
Offline ebclr
Re: Decoding ESP-NOW Radio Transmission intercepted by HackRF
« Reply #1 on: September 13, 2022, 07:54:10 am »
GitHub ?
« Reply #2 on: September 18, 2022, 11:59:29 am »
github.com/bb1gfd/Decoding-ESP-NOW-trasmission
input binary files added
The following users thanked this post: Ghanou
