Author Topic: Do I get this timing chart right ?  (Read 2714 times)
Offline Back2VoltsTopic starter
« on: July 17, 2017, 12:38:06 am »
I need help with this timing chart from the ST7735 datasheet.    It is the timing for the bi-dir SPI + data/command line configuration.     My concern is with the D/CX signal line.    I am correct understanding that the driver reads the D/CX during the first clock period for the byte, that is the first bit being sent, and it does not care for its level for the rest of the byte ?
I will appreciate your comments
Tony
Re: Do I get this timing chart right ?
« Reply #1 on: July 17, 2017, 01:13:08 am »
Based on this entry I found I may be wrong:
https://users.ece.utexas.edu/~valvano/arm/ST7735.c
// The Data/Command pin must be valid when the eighth bit is
// sent.
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #2 on: July 17, 2017, 02:46:06 am »
That code sends the data in parallel to a hardware serializer, so it has no choice but to set D/CX for the entire period (even if the ST7735 does not require it).
According to figure 9.3.3, D/CX must be valid during the last bit of each byte.
« Reply #3 on: July 17, 2017, 04:16:06 am »
Bruce, thank you.    I should have kept reading looking for more details.    Right around the picture you posted there is some text indicating DCX is sampled on the edge of the eighth SCLK cycle.
Tony
