Author Topic: DS18B20 problems Raspberry Pi  (Read 2550 times)
Offline 5321488Topic starter
« on: May 16, 2017, 09:03:07 am »
I am trying to connect a DS18B20 sensor to a raspberry pi. I have done and double checked all the setup code - w1-gpio, w1_therm, added them to startup modules list and added dtoverlay=w1-gpio to config.txt. But the sensor doesn't show up in /sys/bus/w1/devices/ - instead I get a variety of dodgy 00-x00000000 style IDs, with x being a number 1,4,8,6,++. Additionally, the w1_slave directory is not in the device ID directory.
Any ideas on what's wrong? Is it a dodgy sensor?
Offline Mr.B
Re: DS18B20 problems Raspberry Pi
« Reply #1 on: May 16, 2017, 09:12:47 am »
Post your wiring diagram...
Are you using it in parasite power mode?
If so, are you pulling the data line high with a 4K7 or close to that?
Need more information to supply advice.
« Reply #2 on: May 16, 2017, 09:44:39 am »
Schematic attached, basically running off 3.3V, data pin pulled high with 4.7K and connected to pin 4 of Pi.
I don't know about parasitic power mode.
I mostly referenced this tutorial: www.core-electronics.com.au/tutorials/temperature-sensing-with-raspberry_pi.html
