Author Topic: [solved] Eclipse failure  (Read 2713 times)
Offline legacyTopic starter
« on: November 22, 2016, 03:12:28 pm »
!SESSION 2016-11-23 15:59:57.265
eclipse.buildId=M20060921-0945
java.version=1.8.0_25
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY system.bundle 4 0 2016-11-23 15:59:57.968
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle system.bundle.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1010)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:966)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:549)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:484)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:275)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.launch(StartLevelManager.java:245)
at org.eclipse.osgi.framework.internal.core.SystemBundle.resume(SystemBundle.java:155)
at org.eclipse.osgi.framework.internal.core.Framework.launch(Framework.java:503)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.java:51)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:289)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:173)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.IllegalStateException
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.checkSystemState(BaseStorage.java:654)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.getStateManager(BaseStorage.java:634)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.getPlatformAdmin(BaseAdaptor.java:385)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook.frameworkStart(EclipseAdaptorHook.java:80)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStart(BaseAdaptor.java:260)
at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start(SystemBundleActivator.java:55)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:991)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:985)
... 18 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2016-11-23 15:59:57.968
!MESSAGE Startup error
!STACK 1
java.lang.RuntimeException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle system.bundle.
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:557)
!SESSION Wed Nov 23 15:59:57 GMT 2016 ------------------------------------------
!ENTRY org.eclipse.core.launcher 4 0 2016-11-23 15:59:58.00
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.NullPointerException
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:186)
I installed Eclipse on Windows XP/32
and I got this error, and I am lost
any tips ?
« Last Edit: November 23, 2016, 08:22:32 pm by legacy »
Offline ale500
Re: Eclipse failure
« Reply #1 on: November 22, 2016, 04:56:27 pm »
You already have a time machine.... can't you get the fix from next week ? /yoke
(Today is the 22nd of November).
Which version are you trying to run ?
Offline Sal Ammoniac
Re: Eclipse failure
« Reply #2 on: November 22, 2016, 05:18:29 pm »
Try asking on the Eclipse forum. You're more likely to find someone who can help over there.
https://www.eclipse.org/forums/?
"That's not even wrong" -- Wolfgang Pauli
Online nctnico
Re: Eclipse failure
« Reply #3 on: November 22, 2016, 05:44:47 pm »
It could also be a very old version of Eclipse. I'd use google to find the answer.
Re: Eclipse failure
« Reply #4 on: November 23, 2016, 08:22:13 pm »
solved  :D
the problem was related to java
the installed JRE was "too new"
I reinstalled v5 u55 and everything
is now working fine  :-+
