Wow! I didn't mean to resuscitate such a rabbit hole.
And yes, I know very well that a new language won't help solving concrete problems and won't save but make me waste time but, as a hobbyist, I can sometimes afford some procrastination.
Also I was (partly) aware of rust's limitations such as lack of standardization but, in this specific case my digression has been motivated by limitations of well standardized languages.
When I was younger we had only K&R C and one of its "feature" most aggravating to me was automatic promotion of function parameters (e.g. the infamous float to double). I thought that this crap was gone with the advent of function prototypes in the early stages of the standardization process but, alas only to discover (now that MCU learned/forced me to look into assembly code) that automatic type promotion is still there even if only in variadic functions. Ok, sure, nothing that you can't live without but WHY??? ( The other topic emerged in the thread against rust is portability, yes C is very portable but only thanks to is UGLY preprocessor and macro language
The other trigger has to do with partial template class specialization not doing what I had liked, but this case is still under investigation and I may be wrong. I'm confident however that even if C++ is fully defined and standardized, its standard is a complete mess! Sure born from the competing exigences of innovation and compatibility with old codebase but, boys, even FORTRAN has done better job in evolving its standard!
Anyway I'm digressing, I'm writing this to thank you all from preventing me waste my time. I still hope that somewhere lies a better language that, even if not solving problems for me, can make my programming experience less frustrating but again, (to use Mario's words) our princess is in another castle...
A particular thank to janoc for having been explicit on many relevant aspects.
I have started to tinker with it on some toy projects of mine.
[...] Where there are rough edges is the very immature ecosystem where there simply aren't as many packages ("crates") available and what is available are often one-man projects with little support and frequently abandoned.
[...] the reality is that if your use case doesn't fit into the (fairly small) niche where there is good library support already, the language and ecosystem aren't going to be of much use to you.
[...] Rust feels a bit like the language syntax hasn't been designed but "grown" - "Oh, crap, we didn't think about this, let's make the programmer write an apostrophe here and there to indicate this!" And that despite that there is no formal standard out yet and the language is still pretty new (~10 years) and still in flux.
[...]Worse, a lot of this "noise" comes from very low-level implementation detail boilerplate that "leaks" out and the user is forced to deal with it explicitly - like annotating the variable lifetimes. In some cases the compiler can infer it but in many it can't, which kinda sucks and leads to "line noise" statements like:
fn f<'a, 'b>(s: &'a str, t: &'b str) -> &'str {...}
(that's a function taking two string arguments by reference with different lifetimes annotated by those 'a and 'b annotations and returns a reference to another string)
It is certainly not the worst stuff I have seen and I get why it is necessary for the compiler to know this - ever shot yourself in the foot by operating on a pointer/reference to a temporary that has been destroyed in the meantime? This is what the lifetimes are trying to address in Rust. However, the way it is done is really ... meh. A bit of wasted opportunity to design a language that isn't "write only" here, IMO. Of course, C++ is much worse in this regard - but C++ is also 40 years old and carries a lot of historical baggage with it.
