I am using embedded Rust with the Raspberry PI Pico (RP2040). I may apologize for being on topic but let me tell you my experience with it.
First, the reason I went for Rust is that I wanted a better C. I wanted a system programming language
https://en.wikipedia.org/wiki/System_programming_language as that seems to make sense for embedded programming. I know we have options like embedded Python but I will admit to be preconceived that this is for beginners :-).
For a system language I expect it to have no (mandatory) garbage collection nor need for any environment (C++ exceptions requires this). Not for the usual reasons which I disagree with: garbage collection can be real time and people forget that malloc also has issues like memory fragmentation and varying runtime. But it should be lean. Do nothing except what I programmed and have little extra bagage in the binary.
Why a better C? I am working in a different project where the client specified C. Therefore it will be C. It has to interface to some rarely used Linux kernel network system calls. I spent a week chasing a mistake where nothing made any sense. The program did not crash, it just did not work as it should. I was convinced the Linux call, which is very poorly documented, was not working and that I must be using it wrong. Turns out to be an off by one error on a buffer allocation. The size of the buffer is decided by equally poorly documented macros from some Linux kernel header files. The buffer size needed to be +1. This made the kernel call override some random variable on my stack and from there on the program behavior was fucked in a way you could never tell from reading the code. Maybe other people are just better than me, but I want a language with bounds checking please.
There are of course a ton of other improvements by using Rust. Safe memory allocation, safe multithreading etc. Modern tools.
So for my RP2040 project I decided to go Rust. I haven't given up but it sadly it has been a very steep learning curve. The documentation stinks. It is easy enough if you just want to make a blinking LED demo project. But I need to program the PIO, use DMA transfers and interrupts. All the fancy stuff. And there simply is _no_ documentation! No blog posts that aren't outdated. There is some autogenerated documentation, with half the links broken and the other half only understandable by someone who knows Rust and the embedded libraries very well. Oh and everyone points you to the outdated "embedded rust book" that skips over all the juicy bits and only gets you to the "blinking LED" stage.
I ended up with something half working but I found my Cargo.toml with a huge list of dependencies, half of which I am unsure if are really needed. And then the PIO assembly macros for Rust advertised that it would compile the PIO instructions at compile time. Which fails because suddenly the whole thing expects my Pico to depend on std so it can make colorful error messages on the non existing console?
Apologies for the rant. I _will_ make it work. But I fully understand if someone just skips this nonsense and gets the job done using C instead.
