Author Topic: Embedded Simulation  (Read 2086 times)
Offline whattyTopic starter
  • Country: in
Embedded Simulation
« on: August 10, 2023, 10:15:03 am »
Hi, I am doing a project where I want to check the temperature sensor and upload data to an E-ink display for this I am using an STM8L microcontroller. I had developed the required hardware and code for the project and wanted to test it before buying actual hardware components. Where can I simulate these?
Thanks in advance.
Offline HwAoRrDk
Re: Embedded Simulation
« Reply #1 on: August 10, 2023, 11:20:25 am »
You can use ucSim simulator that comes as part of SDCC compiler. But that only really simulates the CPU and limited peripherals of the STM8 (like UART, perhaps timers, I forget exactly what). So mostly only useful for testing specific parts of firmware code, and not a complete system.
The following users thanked this post: whatty
  • Country: in
« Reply #2 on: August 10, 2023, 12:05:00 pm »
Hi, Thanks for your suggestion. Can you share me the usim webpage.
Offline HwAoRrDk
