Ha, yeah, Hackaday has turned to crap postings the last few years IMHO. Is there any other news/blog site noteworthy of checking out for cool designs?
This letter was written back in 2011!!! And it is about the old (outdated) MPLAB IDE. The main IDE now is MPLAB X and because it's based on Netbeans it is supported on Linux too. And it is MUCH better than the old MPLAB IMHO. Although there are still some folks out there who claim the IDE is awful, i have to say that my experience with it is VERY positive. Lately i'm doing some work with Keil, and it crashed on me twice, without any warning! One of the crashes corrupted my project file, so i had to start over by creating a new project! Never had that experience with the MPLAB X.
I think people can share similar experiences for all IDE's. I can say I've had to recreate a MPLAB X project because otherwise the debugger couldn't figure out what line C code complies to what assembler (PIC24 project).
I've ranted more about MPLAB X in the past, and it's getting better now, but the slowness of Netbeans still bothers me. I say this on a fast machine (SSD/16GB RAM/i5 3570K CPU), and any non-Java based IDE beats it in terms of speed any day of the week. To get rid of that, ideally an IDE needs to step up with QT.
(As a side note: i'm still eager to try out Qt developer environment for ARM, including debugging. I think it should be possible, given there is a GDB server for ARM + open ARM GCC tools).
Microchip offers FREE editions of their compilers for all their families, and XC8 has become better since version 1.21.
Yep, I still can't imagine people say Microchip is not free. They provide a reasonable set of compilers that work out of the box in MPLAB X.
PICKIT 2/3 is ~50 euro's for a standalone programmer + debugger, (
PK2 can also be used as a AVR programmer using avr-dude). In Atmel world this buys you an AVR dragon, but they forgot to make an enclosure for that.
I guess it's a close call.
And if you want you can still use the legacy HI-TECH C compiler for the 8 bits in MPLAB X in lite mode. And PIC18 + XC8 free or HI-TECH C lite will OUTPERFORM the Arduino anyday, so it is your loss for not using the PIC.
It will probably outperform programs written using the Arduino runtime. That's horribly slow, where I recall a simple digitalWrite action can take up to tens of microseconds.
As in the architecture of PIC16/18, it's actually completely terrible compared to anything else and modern. Only 1 accumulator register, banked memory, Fosc/4 clock speed, etc. But it works.
There is a reason it still uses HI-TECH compiler. Microchip failed themselves to make a decent one, and therefore bought out HI-TECH. They made attempts to port it to GCC or LLVM, but that failed too, as the architecture was so odd it couldn't made to fit with modern compilers.
Also the XC8 compiler has it's limitations, and all MCP compilers speak a very strict dialect of C to much annoyance. In addition, XC8 optimizations at the FREE level are to say the least "odd".
I think this is a well known story for those who have argued with an Atmel fanboy, as they will always bring this up. And I regard it as true, but then again I try to avoid using the PIC16 & 18s a bit.
Luckily though, their XC16 & XC32 compilers are GCC (with O1 optimize which does most good stuff).
Moreover it's not hard to figure out how to run all compilers in their most optimal setting. As XC16 and XC32 are based on GCC,
their source code is found online, including the part that speaks to the license manager, which means it's actually incredibly easy to figure out a replacement manager to run it in original intentions
As for the demise of the 8-bitters, it will happen, but only for more complicated projects. Currently i'm working on 2 projects that are so trivial, (simple user interfaces) even the PIC16 series is overkill. I think that the 8-bitters will continue to hold this (low end) market for the years to come.
I'm designing a digital power supply at the moment, and I'm likely to put a PIC24 or STM32 chip in it. Mostly for cost/performance (which I don't really need, though), but also so I have similar/identical code for most of my projects (saves time).
I would only use 8-bit chips if for package or power consumption.
