Author Topic: Error loading Arduino uno program  (Read 5919 times)
Offline PROGRAMERTopic starter
  • Country: si
« on: February 04, 2016, 10:25:33 pm »
Arduino: 1.6.6 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1,174 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "\\.\COM7": Access is denied.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
AND
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xde
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xde
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Offline sleemanj
  • Professional tightwad.
Re: Error loading Arduino uno program
« Reply #1 on: February 04, 2016, 10:43:47 pm »
Most likely to least likely (not an exhaustive list):
Incorrect Arduino board selected in Arduino IDE.
Incorrect port selected in Arduino IDE.
Incorrect driver installed in operating system.
Dead Arduino.
Incorrect operating system permissions.
Offline captbill
« Reply #2 on: February 04, 2016, 10:49:02 pm »
You seem to have the wrong target configured. You are trying to upload to an Stk500 chip. Go 'tools|board' and choose 'Arduino UNO' and the go to 'Tools|Programmer' and choose 'AVR ISP'. Make sure you have the right com port too.
Offline sleemanj
« Reply #3 on: February 04, 2016, 11:36:57 pm »
The serial bootloader emulates an stk500 programmer (or better said, the arduino serial bootloader uses the same protocol as the stk500).
