Author Topic: ESP 32 is fa.........st  (Read 2538 times)
Offline ebclrTopic starter
« on: February 19, 2017, 02:31:31 pm »
Quick reply without calculating
What will be signal frequency on output5, on a standard esp32 board using Arduino and espressif
void loop() {
  // put your main code here, to run repeatedly:
  digitalWrite( 5,HIGH );
//  delay(100);
  digitalWrite( 5,LOW );
//  delay(100);
Offline cowana
Re: ESP 32 is fa.........st
« Reply #1 on: February 19, 2017, 02:48:19 pm »
No idea!
But if a 16MHz ATMEGA328 manages about 200kHz with the bloat of digitalWrite, I'd expect somewhere around 3MHz from an ESP32 running at 240MHz?
« Reply #2 on: February 19, 2017, 02:50:00 pm »
Amazing 3.65 Mhz
Offline daybyter
« Reply #3 on: February 19, 2017, 09:50:08 pm »
How fast is analogRead ?
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #4 on: February 20, 2017, 12:33:57 am »
Or, without the bloat...
.include "m328def.inc"
 ldi  r16,1<<5
 out  DDRB,r16
loop:
 out  PINB,R16
 rjmp loop
2.67MHz (3.33MHz @20MHz)
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: February 20, 2017, 01:40:29 am »
It's no secret that the pin operations in the Arduino main core are very bloated and slow.
Frustratingly it would be possible to refactor the functions (pinMode, digitalWrite, digitalRead...) a bit and use some GCC compile-time magic to make serious optimisation for constant (compile time known) arguments such that a digitalWrite or pinMode for example would be optimised down to a single sbi or cbi instruction, like I did for my ATTinyCore fork
But I think any such pull request on the main arduino core would probably languish in the pit of "oh but it might break [insert random thing that a developer happens to use] which was relying on the slowness".
