Author Topic: ESP32 Arduino WiFi Manager & File System (SPIFFS)  (Read 12113 times)
Offline ProtoG42Topic starter
« on: January 22, 2018, 03:30:30 pm »
The ESP32 is finally starting to become compatible with more and more popular Arduino libraries.
In the video I demonstrate using the WiFi Manager library for ESP32 in the Arduino IDE as well as the SPIFFS file system for the ESP32. It allows people to avoid having to hard code wifi credentials but in the video I show that it can also be used to add several other variables and parameters. Adding a few lines of code to the WiFiAP.cpp file allows the configuration screen to automatically pop up on a phone or computer when logging into the ESP32 set up SSID. Also, in the video I show the 3 lines of code that you can use to reset the wifi credentials and wipe the memory so you could make a physical reset button for a product.
Here are the main github libraries needed:
ESP32 Arduino Core: https://github.com/espressif/arduino-esp32
WiFi Manager: https://github.com/zhouhan0126/WIFIMANAGER-ESP32
WebServer: https://github.com/zhouhan0126/WebServer-esp32
DNSServer: https://github.com/zhouhan0126/DNSServer---esp32
Add these 3 lines of code to line 95 of WiFiAP.cpp to automatically pop up the configuration screen after connecting to the access point:
tcpip_adapter_dns_info_t dns_info;
dns_info.ip.u_addr.ip4.addr = IPAddress(192,168,4,1);
tcpip_adapter_set_dns_info(TCPIP_ADAPTER_IF_AP, TCPIP_ADAPTER_DNS_MAIN, &dns_info);
The following users thanked this post: ralphrmartin
Offline ralphrmartin
    • Me
Re: ESP32 Arduino WiFi Manager & File System (SPIFFS)
« Reply #1 on: January 25, 2018, 05:24:33 pm »
One thing missing - where is the source for your Arduino program? You only tell us about the libraries..
« Reply #2 on: January 27, 2018, 07:40:21 am »
It is linked in the video description.
Offline 1anX
« Reply #3 on: January 27, 2018, 08:57:19 am »
Good info, thanks for posting!
    • Me
« Reply #4 on: January 27, 2018, 07:32:15 pm »
Thanks!
By the way, what board type do you use in Arduino for this particular TTGO board?
« Last Edit: January 27, 2018, 08:17:59 pm by ralphrmartin »
Offline mdumdei
« Reply #5 on: October 31, 2018, 11:19:27 am »
I'm not seeing the link in the description - just text. I'm experienced with programming and electronics, but just getting started with this stuff and would love to go through the code. Looks like a good example of WiFi, JSON, SPIFFS - lots of good stuff.
