Author Topic: esp32 programming software  (Read 5460 times)
Offline Riccardo_TommasinTopic starter
« on: March 08, 2020, 06:28:33 pm »
Hi, i was wondering if there are some programming software for the esp32... i was searching for something like atmel studio for avr..
thanks.
Offline aldi
Re: esp32 programming software
« Reply #1 on: March 08, 2020, 08:42:21 pm »
Offline ebclr
« Reply #2 on: March 09, 2020, 04:27:08 am »
Offline Lindley
« Reply #3 on: March 09, 2020, 09:52:13 am »
The Arduino IDE now has ESP32 support and works ok.
https://randomnerdtutorials.com/installing-the-esp32-board-in-arduino-ide-windows-instructions/
If you want a more comprehensive IDE then the free Atmel Studio with Visual Micro plug in allows you to run Arduino and ESP32 projects.
Offline Doctorandus_P
« Reply #4 on: April 02, 2020, 02:58:05 am »
Look around a bit for: "Wemos D1 Mini" and for "Platformio"
Some time ago I bought a bunch of ESP8266 boards and got them to work by just plugging in an USB cable.
Can't recall any trouble with them either, they just worked.
Then I discovered I liked playing with hardware such as dedicated motor timers and such more and attention wavered to other projects.
What I liked of the Wemos boards is their ease of use (Just plug in USB), addon boards for sensors and stuff, their small size and breadboard compatibility and their low price. If you damage a few of these boards (for example over voltage), well, each mistake will cost you EUR3. They are a bit more expensive then the bare ESP12 modules but a lot easier to work with. Get some ESP12 modules too, for if you want to build small projects, or put them on another PCB.
« Last Edit: April 02, 2020, 03:01:42 am by Doctorandus_P »
