Author Topic: ESP32: Upload issue  (Read 1619 times)
Offline mwesternTopic starter
ESP32: Upload issue
« on: October 15, 2020, 07:37:41 pm »
I am having a problem uploading my code using the arduino IDE onto my esp32. I am new to this and have never seen these issues before, I have my own programming board which I have used for other projects so I do not believe that to be the issue. Attached is a photo of the errors I am receiving and my code.
Offline drvtech
Re: ESP32: Upload issue
« Reply #1 on: October 15, 2020, 10:05:01 pm »
Sorry if this is a bit basic but have you put it into boot mode before trying to upload? See here for details https://github.com/espressif/esptool/wiki/ESP32-Boot-Mode-Selection
The following users thanked this post: mwestern
Offline Lindley
« Reply #2 on: October 16, 2020, 08:45:34 am »
Which ESP32 board are you using ?  ours just work fine out of the box.
Have you tried uploading  the basic Arduino  Blink example ?
Always try a different USB cable and pc socket, some can cause uploading problems.
Offline Lindley
« Reply #3 on: October 17, 2020, 11:00:54 am »
Also, depends on what board from the Board manager you have selected.
Not all boards program up on the original 'ESP32DevModule' setting.
