Author Topic: ESP8266 - BASIC - PCF8574 Drivers Example  (Read 3248 times)
Offline TJ232Topic starter
  • www.esp8266-projects.org
    • ESP8266 Projects
« on: August 04, 2016, 11:45:11 am »
If you didn't use it before, it might worth to give it a try: www.esp8266basic.com. Latest Version 3.0 looks impressive, is using websockets and is full of goodies.
Please find below also some handy ESPBasic I2C related examples:
  - ESP BASIC Series - Ep.1 - I2C Bus Scanner Software tutorial - A nice & tiny piece of software that can help you with your ESPBasic & I2C related projects:
  - ESP Basic -1 - PCF8574 I2C I/O Expander Driver example - How to implement a interactive web interface for a mutually exclusive 8x1 Switch.
« Last Edit: August 06, 2016, 08:17:31 am by TJ232 »
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
    • ESP8266 Projects
Re: ESP8266 - BASIC - PCF8574 Drivers Example
« Reply #1 on: August 06, 2016, 08:19:29 am »
Have done also the step-by-step tutorial also for the PCF8574 Driver for a 8 x Independent Switches implementation:
Related full article : ESP8266 Basic Series - Part 3 - PCF8574 Driver for a 8 x Independent Switches
Credit for the XOR bit masking technique goes this time to forlotto from esp8266.com forum who was quicker in posting than me :)
