Your requirement for point-to-point effectively counts out MQTT for your application.
Just be aware that this pushes the subscription table management back into the IOT device. This will cause problems if the number of subscribers grow. At some point you run out of RAM to hold the subscriptions.
In my case, the number of subscribers is quite large, so the MQTT broker is a nice beefy server. All the data source MQTT nodes can be small, needing only to manage one communication path to the broker.
